Jd 110 Round Fender Engine, 7hp Vs 8hp
1 reply to this topic
#1 drhntrrmw OFFLINE
drhntrrmw
  • 3 Thanks
  • 15 posts
Posted September 25, 2012 - 12:04 PM
I'm looking for information regarding when JD made the switch from Kohler 7hp to the 8hp.
Some of the in formation out there says they switched to the 8hp in 1965 but my 1967 110H has the 7hp.
Any info would be great, THANKS!!
#2 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted September 25, 2012 - 01:46 PM
'64 was the first year for the k181. This is from WFM
The Model 110 The model 110 was John Deere’s first Lawn & Garden tractor. In 1962 a design was laid forth to build a lawn and garden tractor that would offer many of the same features and wide range of implements that the bigger John Deere tractors offered. It would offer small rural and urban landowners alike the chance to own an affordable Small Tractor with a Big Farmer feel. The new tractor was designated the John Deere Model 110 in keeping with the current Ten Series Waterloo and Dubuque tractors. Ergonomically designed, with new features way ahead of its time, its exclusive Variable Speed Drive allowed for high speed mowing and super low end tilling. Its stout, and dependable Cast Iron 7 hp K-161 Kohler engine gave the tractor plenty of power to utilize the integral worktools. It was a great design, and was quick to become a big seller with 1000 models built for 1963. Features included:
  • Seven horsepower, air cooled, Kohler model K161 cast iron engine with electric start
  • Peerless three speed transmission with speed variator that allowed slowing the tractor without interrupting power to the driven equipment
  • Rear tires and drive belts enclosed and shielded for operator protection. A full hood and grille protecting the engine, battery, starter, etc.
  • Quick -Tach style mounting of attachments
  • Scratch resistant fiberglass hood and fenders
  • Triple safe starting
  • Heavily built frame and front axle to handle heavy loads.
  • Adjustable tread rear wheels, important for mowing on hillsides.
Introduced as a seven horse model in 1963, for 1964 an eight horse Kohler K181S was utilized and the fiberglass fenders were replaced with steel. For 1965 the transmission was changed from three speed to four speed, and in 1966 Hydraulic Lift was offered as a factory only option. In 1966 a new 110 with Manual Lift cost $719 and the standard 38" deck was $148.
Triple safe starting was a feature from the start. The PTO needed to be disengaged, the transmission in neutral and the key used before the tractor could be started. This feature was advertised by showing children playing and climbing on the tractor. Deere considered the safety feature to be a key selling point on the tractors.
The most obvious design change was in 1968 when the separate "round fenders" were replaced by a one-piece "fender deck" that was rubber mounted to the frame. The next significant change occurred in 1972 with a larger, heavier frame, choice of the 8 hp Kohler K181S or a 10 hp Kohler K241S engine. Electric lift became an option in 1973.
The model 110 initially weighed approximately 500# with the later versions adding weight to a total of 775#. The 110 was designed as a garden tractor and Deere offered many integral attachments to suit the homeowner, as well as the commercial user :
  • Model 20 Compressor
  • Model 38, 39 and 46 (for 10hp) mower deck
  • Model 36, 37, and 37A snowthrowers
  • Model 30, 31, and 31A rear rotary tiller
  • Model 42 and 43 blade
  • Model 80 dump cart
  • Model 7, 5a, and 5b sprayer
  • Front and rear slab weights and rear wheel weights
  • Tire chains, hub caps, cigarette lighter, and headlights
  • An integral hitch
  • Tire equipment options
Serial number breaks are as follows: Year Serial Number Engine 1963 2,550 - 3,550 Kohler K161 (7hp) 1964 3,551 - 15,000 Kohler K181 (8hp) 1965 15,001 - 40,000 Kohler K181 1966 40,001 - 65,000 Kohler K181 1967 65,001 - 100,000 Kohler K181 1968 100,001 - 130,000 Kohler K181 1969 130,001 - 160,000 Kohler K181 1970 160,000 - 185,000 Kohler K181 1971 185,001 - 250,000 Kohler K181 1972 250,001 - 260,000 Kohler K181 1972 260.001 - 272,000 Kohler K241 (10hp) 1973 272,001 - 285,000 Kohler K181 1973 285,001 - 310,000 Kohler K241 1974 310,001 - 320,000 Kohler K181 1974 320,001 - Kohler K241
  • WHdbJD said thank you
