Cl - Kubota L1500dt 4x4 Acreage Tractor - $2600 (cb)
kubota diesel omaha craigslist
This topic has been archived. This means that you cannot reply to this topic.
No replies to this topic
#1 Trav1s ONLINE
  • 3,411 Thanks
  • 4,434 posts
Posted September 25, 2012 - 07:37 AM
I am selling my Kubota tractor. It is a 17hp 2 cyl diesel. I have had the tractor for a few years. used it for mowing and minor dirt work with a 4ft scraper bucket (which I would sell separately)
It is a 4x4, 4 spd tranny with H/L, and transfer case to disengage front axle when not needed. It has a 4 spd PTO as well and has no problem handling a 5 ft rear mower. It has been very well maintained, oil changed frequently using mobile 1 Delvac heavy duty engine oil. Tires are in good shape and do not leak air. everything works on it. I got it ford blue, but i am sure it could easily be repainted the slate gray it should be.
I have in the past month put new exhaust gaskets, a new alternator, starter, battery cables and glow plugs in it. The only thing it could use now is a new battery. The reason I am selling it is because I got a newer John Deere acreage tractor.
