Need To Find Replacement Disc - Where To Find?
12 replies to this topic
#1 Chris4x4Gill2 OFFLINE
Chris4x4Gill2
  • 7 posts
Posted September 24, 2012 - 01:06 PM
Hello everyone.
I use an older - not sure of the year- garden tractor disc modified to fit behind my ATV. I have broken one of the discs and am having trouble finding a replacement.
When I bought it, I was told it was originally from Sears - its a heavy duty unit set up for a small 3 point hitch. Double row Disc Harrow with 16 total blades.
The disc (blade) I need to replace measures is smooth, 10 3/4" in Diameter, 1 1/2" dish, with a 20mm (.82") round center hole.
All of the blades are the same. I would like to find replacements or swap out to notched blades that will fit.
Any suggestions on where to find replacement pieces?
Edited by Chris4x4Gill2, September 24, 2012 - 01:07 PM.
#2 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted September 24, 2012 - 02:06 PM
If anybody is likely to have them this place will.
http://www.agrisupply.com/
#3 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted September 24, 2012 - 02:11 PM
Brinly has replacement blades, but the price shown is not correct. If you call them, the actual price is actually around $25 per blade, the last I heard.
https://brinly.3dcar...arrow_c_29.html
Ebay is another option.
I like the link JD supplied. Much better prices. Will a 12" work?
http://mower-blades....isc blade&asug=
Edited by Cat385B, September 24, 2012 - 02:20 PM.
#4 Chris4x4Gill2 OFFLINE
Chris4x4Gill2
  • 7 posts
Posted September 24, 2012 - 02:12 PM
I've looked there and they only list 14" and larger.
I havent measured yet to see if I can go up that much in size yet as I was still hoping to replace the single broken disc, vs swapping all 16 out for now.
#5 Chris4x4Gill2 OFFLINE
Chris4x4Gill2
  • 7 posts
Posted September 24, 2012 - 02:13 PM
Although looking closer I do see a couple 12" listed. I'll have to just give them a call instead of trying to search their website.
#6 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted September 24, 2012 - 02:18 PM
I looked at the Brinly and Agri Fab sites and their discs both seem to be 11" ones.
Brinly uses the smooth discs, and Agri-Fab notched.
Brinly lists replacement discs at 9.89 ea. https://brinly.3dcar...arrow_c_29.html
Agri-Fab lists their notched discs at 28.25!
#7 KC9KAS ONLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted September 24, 2012 - 03:16 PM
Guys, where are your manners?
Chris4x4Gill2...Welcome to GTT!
#8 Chris4x4Gill2 OFFLINE
Chris4x4Gill2
  • 7 posts
Posted September 25, 2012 - 07:09 AM
Thanks for the Welcome KC.
And thanks for the links guys.
Agrifab has the notched 12" for about $7.50 each. Those should fit without a problem, but I need to measure to be sure. I would like to swap out the frotn gang to all notched to cut better, but that may have to wait.
Great little site you guys have here. I dont have a garden tractor, just use some of the older implements behind my ATV. I wish I could justify one though, but Im afraid it would be one mroe hobby I dont have time for.
#9 Chris4x4Gill2 OFFLINE
Chris4x4Gill2
  • 7 posts
Posted September 25, 2012 - 07:56 AM
Well the one from Brinleys wont fit - The ID is too small. Going to check with Agri-fab now.
Any issue running a single 12" with the rest being 11" ? I mean as long as it fits? I wouldnt think the extra 1/2" would cause any problems but...... just checking
#10 Alc ONLINE
  • 7,240 Thanks
  • 7,586 posts
Posted September 25, 2012 - 08:21 AM
Chris could you use the 11" one and just open the hole up to 22mm with a die grinder and stone ? Al
#11 Chris4x4Gill2 OFFLINE
Chris4x4Gill2
  • 7 posts
Posted September 25, 2012 - 02:35 PM
I thought about that, I dont think runout would be a concern since its not turning any type of rpm. Its an option, still looking for an off the shelf though.
Would there be any concern / downside to running a new set of 12" notched in the first gang with the original 11" smooth in the second? If anything, should make the front gang cut al little better i would think.
Edited by Chris4x4Gill2, September 25, 2012 - 02:37 PM.
#12 MH81 OFFLINE
  • 29,979 Thanks
Posted September 25, 2012 - 05:44 PM
Chris, does your setup have an adjustable toplink? If so, you should be able to compensate for the size difference. Unfortunately, the OEM discs from Sears are NLA, the part number for most of them was 6844M, for what it's worth.
Btw, the notched ones only make a difference in rocky or sod clump ground, at least that's been my experience.
Oh, and :welcometogttalk:
#13 Chris4x4Gill2 OFFLINE
Chris4x4Gill2
  • 7 posts
Posted October 15, 2012 - 09:58 AM
Thanks for the information. To update this somewhat - I was unable to find a direct replacement so I ran it a disc short this time. Will try this next year to figure something out before I use it again next fall.
The top link it is home made and is set right now. I can disasseble and drill some mroe hoels to adjust it though if need be.
I am still leaning towards swapping in some larger notched discs, this is used for Deer plots at our hunting camp so rocks, sticks, etc are common no matter how well i clean the area first.
