Homebuilt Blasting cabinet
8 replies to this topic
#1 caseguy OFFLINE
  • 1,629 Thanks
Posted August 01, 2010 - 09:41 PM
  • dstaggs, ducky, sacsr and 1 other said thanks
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted August 01, 2010 - 09:52 PM
That is great.
I have a smaller one but always thought it would be useful to have a large one like yours.
#3 olcowhand ONLINE
  • 42,894 Thanks
  • 31,937 posts
Posted August 01, 2010 - 10:03 PM
I like it! But using the pot & having to refill is time consuming, plus if there is any moisture, you'll run into media blocking up. My cabinet uses siphon feed right from the bottom of the funneled floor & never gives any problems whatsoever. If you have feeding problems, I suggest going to siphon feed. You'll have to buy a siphon style gun, but the pickup siphon tube you can make yourself. You did a knock-out job building that cabinet!
What are you doing for dust filtering?
#4 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted August 01, 2010 - 10:04 PM
Now tell me how to make a dryer for air commpresor chep
#5 caseguy OFFLINE
  • 1,629 Thanks
Posted August 01, 2010 - 10:11 PM
For now I have exhaust fans coming out of the cabinet right next to an exhaust fan that goes outside and I wear a respirator, but it's less than perfect. I saw your posts on the wet dust filter system and I've got my lines out looking for the stuff to build one. Fantastic idea by the way! I have 2 siphon feed setups and I thought that they were a little on the slow side. Of course you're right about the refill taking a lot of time too. Wouldn't be too hard to block the funnel at the bottom as it is just the top off of a bottle of Lucas.
Edited by caseguy, August 01, 2010 - 10:22 PM.
#6 caseguy OFFLINE
  • 1,629 Thanks
Posted August 01, 2010 - 10:14 PM
I'm working on an air dryer too. I have an old propane cylinder that I intend to wrap the coolant lines from a dehumidifier around and swirl the incoming air around the sides with the discharge at the top, in the original valve location, and a drain at the bottom. It can be dangerous to weld on things like that, but I'll flood the tank with argon before I weld.
#7 MH81 OFFLINE
  • 29,978 Thanks
Posted August 02, 2010 - 01:52 PM
I've seen it up close, & it's fantastic. Caseguy doesn't usually build things 1/2 way. He left out 1 important fact tho... the weight.
#8 Goltz OFFLINE
Goltz
  • 2 Thanks
  • 11 posts
Posted March 05, 2012 - 05:42 AM
Thanks for idea.
Edited by Goltz, March 05, 2012 - 05:44 AM.
#9 kwj427 OFFLINE
kwj427
  • 57 Thanks
  • 137 posts
Posted December 27, 2012 - 03:47 PM
that looks great!
  • caseguy said thank you
