Double Pulley For Bagger On 48" Mower Deck-1993
No replies to this topic
#1 wpeterson OFFLINE
  • 2 posts
Posted September 22, 2012 - 12:18 PM
Situation: I want to put a bagger attachment on my tractor. I don't have the correct double pulley to drive the bagger impeller.
Question: What is the correct double pulley which goes on the right side spindle of the mower deck to drive the bagger impeller?
1993 Wheel Horse model 73400 Serial #3901213
Mower deck model 78360 48" side discharge Serial #2312(?) (partial) is on foil tag by Ser# tag, mostly unreadable
Bagger model #79301 Serial #79-6890
Mower deck came with tractor so I assume the mower deck is also 1993. Bagger is from a different source, came off a 42" deck, possibly a 1996. The double pulley for that 42" deck is different than the one I need for my 48" deck.
I bought part #79-7130 double pulley. Two problems: 1) this pulley has a 5/8" center hole, and my spindle is 3/4", and, 2) there is no keyway in the pulley. Is this the wrong part, or did my spindle get replaced with the wrong size spindle?
Is there a correct part with the 3/4" hole and keyway?
If I buy a new spindle, will it be 5/8"? Looks like part #112674 for that. I could use a new spindle, as the keyway on the spindle is badly worn.
Any help will be greatly appreciated!
'93 314-8 Classic
48" mower deck
42" snowblower
