Any 3pt Parts Only Out There?
2 replies to this topic
#1 glgrumpy ONLINE
  • 8,552 Thanks
  • 7,878 posts
Posted September 21, 2012 - 10:48 PM
GT14 3pt. I didn't get the lift rods, wondered if ever any parts around w/out rest of hitch??
I need 2 each of ......
8769 lift rods
8522 Pivot w/threads
8521 Pivot Plain
I could make rods out of bigger bolts, not sure what to do for the block ends. Guess could weld a bolt onto square stock or ??? but not so sure I can thread good enough. I would also put "handles" on the bolt head to adjust . Anyone ever make these and have pix or ideas to show/tell? The holes in arms are quite big, bet 5/8 or maybe even 3/4" . I could make clevis's out of flat stock or rect tube welded to nut and go Over the lower arms, much like others have. Would probly be easier that makeing the blocks. Still would need those at top or similar.
#2 KennyP ONLINE
  • 37,439 Thanks
  • 45,468 posts
Posted September 22, 2012 - 02:23 AM
Check out this! Might give you some ideas!
  • jimbobbillyray said thank you
#3 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted September 22, 2012 - 06:22 AM
I dont know how much they have in common but my D series has a 3PTH. You can look upmy vids on you tube and see what they look like.
