C-101ss
8 replies to this topic
#1 thirdroc17 OFFLINE
thirdroc17
  • 37 Thanks
  • 91 posts
Posted September 19, 2012 - 01:50 PM
Technically, she's not "finished" but she's ready enough to go. I don't build trailer queens, and I am NOT a body man, so ignore the runs in the paint, the various shades of paint from different sources over the course of more than a year, and ignore the ripples I didn't get out of a hood that was originally crushed. Ignore everything else that can be seen when standing within 100' as that is my standard. Look ok from 100' or farther away.
Someday I'll get around to making a cover the headlight hole.
Always wanted to make my own muffler, and now I have.
Originally a rubber mounted 10hp, Kohler, now a solid mount 16hp that's been well warmed over and should be making a solid 20hp.
Edited by thirdroc17, September 23, 2012 - 11:49 AM.
#2 jms180 ONLINE
jms180
  • 1,751 Thanks
  • 1,674 posts
Posted September 19, 2012 - 04:16 PM
I think it looks very nice. Looks like it is ready for some snow.
#3 KC9KAS OFFLINE
KC9KAS
  • 5,468 Thanks
  • 4,723 posts
Posted September 19, 2012 - 07:04 PM
As soon as I saw the engine I knew it was "High Performance". Nice looking Horse!
I bet the roller chain on the fronts really help the steering on packed snow/ice.
#4 thirdroc17 OFFLINE
thirdroc17
  • 37 Thanks
  • 91 posts
Posted September 20, 2012 - 09:02 AM
Thanks guys.
I've run a single chain on a front tire in the past as an experiment. It seemed to help. Fortunately, from another project, I had enough used, worn out chain to do both. Buying new roller chain for tire chains isn't in the budget, but patience will sometimes provide....
#5 mjodrey OFFLINE
Posted September 20, 2012 - 09:46 AM
That chain on the front tires does seem like it might grip on slippery going.
#6 caseguy OFFLINE
  • 1,629 Thanks
Posted September 20, 2012 - 04:42 PM
Wow Dale, she looks like a real beast! I can't see any of the flaws that you mentioned. I think the paint looks fine too andI love the look of the muffler!
#7 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted September 20, 2012 - 07:59 PM
Dale, do you have any info on building your own muffler? Is there an article here on it?
#8 jusjeepn OFFLINE
jusjeepn
  • 84 Thanks
  • 120 posts
Posted September 20, 2012 - 11:00 PM
I was wondering about that extended hood... I see why now!!! That looks like one heck of a tuff snow machine! THANKS!!! Now we won't get any snow! Get ahold of me on a headlight bucket and lens or an escutcheon plate. I still owe you my friend!
#9 thirdroc17 OFFLINE
thirdroc17
  • 37 Thanks
  • 91 posts
Posted September 21, 2012 - 09:02 AM
I chose pictures carefully, I could show some where you'd see the paint imperfections in grand detail!!!
I wanted a high flow muffler, but also wanted something quiet. I'm not sure how quiet it is as I've only ran it in the shop, and everything is noisy in there.
This pretty well explains the muffler. I drilled enough 1/4" in both the incoming pipe and out going pipe to exceed the area of the 1 1/2" ID of the pipes. Then just welded the incoming to the opposite side of a 4" exhaust pipe, and one end to a piece of 16 gauge sheet. Welded the sheet to the back so the pipe exited the front.
Drilled a hole in another piece of sheet, set it over the exit pipe and welded everything. Since I'm a crappy welder, it took several beads to get things half way air tight.
The exhaust gas comes in close to the front, divides through the 1/4" holes, travels to the back, divides though the 1/4" holes, and shoots straight out the front.
My original plan involved adding packing along the interior of the muffler, but kind of ran out of room. If I do another, I might try 5" pipe for the muffler body.
