62 Cub Cadet Original
This topic has been archived. This means that you cannot reply to this topic.
3 replies to this topic
#1 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted September 18, 2012 - 05:17 PM
This looks like a pretty cool Cub. If the sickle's in good shape thats worth the price of the machine.
http://binghamton.cr...3220699912.html
#2 twostep OFFLINE
twostep
    Rockstar
  • 1,937 Thanks
  • 2,515 posts
Posted September 19, 2012 - 07:59 AM
dude obviously took a course in photography...
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted September 19, 2012 - 08:34 AM
Why are the gas tank brackets bolted to the front of the tractor.
Also it doesn't have a rear PTO, if he did he would have to remove the sleeve hitch from the because it hit the shaft. It looks like he has replaced the axle housing with later units.
Edited by Amigatec, September 19, 2012 - 08:49 AM.
#4 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted September 19, 2012 - 10:03 AM
Must be he was goingto mount the tank there because it wouldn't fit under the hood with the bigger engine.Then use a fuel pump. It does have a rear pto. You can just see it in the third pic. down.Your right though. I would think it would hit on the 3 point lift.
Edited by LTD, September 19, 2012 - 10:04 AM.
