430 Drive Shaft
6 replies to this topic
#1 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted September 17, 2012 - 10:42 PM
Needing to replace a u-joint on the front of the drive shaft. I have it loose but there does not seem to be enough room to remove it. Will it come out without moving the engine or diff? Hoping someone has a tip of two.
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 18, 2012 - 08:07 AM
Fred, do you have the service manual?
#3 olcowhand OFFLINE
  • 42,433 Thanks
  • 31,812 posts
Posted September 18, 2012 - 10:25 AM
I'll come look at it tonight Fred. Those Green machines sure are hard to work on aren't they! :smilewink:
#4 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted September 18, 2012 - 03:47 PM
I haven't had time to search for a manual yet, was hoping someone had removed one would have some pointers.
#5 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted September 18, 2012 - 04:48 PM
if i was to bet on it id say you have to pull the engine . i had to on my 318 my 317 and 400 and i tried every thing i could think of but they will not come out . hope im wrong
#6 olcowhand OFFLINE
  • 42,433 Thanks
  • 31,812 posts
Posted September 18, 2012 - 06:40 PM
Shaft is out!
#7 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted September 19, 2012 - 10:30 AM
It happened so fast that it was a blur . :confuse:
Best I can tell Daniel removed the hydraulic lines to get enough room for the shaft to come off hydro pump. 10 mins and he was gone like a flash, Thank you Daniel :thumbs:
