Brinly Fitted To Mf1010
6 replies to this topic
#1 olcowhand OFFLINE
  • 38,791 Thanks
  • 30,696 posts
Posted September 17, 2012 - 04:55 PM
Rainy day here, so took some time from farm work to fit a Brinly 10" sleeve plow to my Massey 1010 diesel. I had a flat bar made up & on my lift arms to keep a hitch ball on for moving trailers/etc. I didn't have a 3rd arm tower on it, so I made up a bolt on one. I welded some heavy 5/8" ID short bushings directly onto the bar in the approximate spot needed for proper plow placement. Fine tuning can be done via the stabilizer arms.
I now have 3 tractors fitted with plows for my plow day for myself, George, and Grand, and a 4th plow for B10dave if he needs it. I'll try to get pics later this evening.
#2 Wheel Horse Kid OFFLINE
Wheel Horse Kid
    Certified Wheel Horse Nut
  • 213 Thanks
  • 817 posts
Posted September 17, 2012 - 05:19 PM
Sounds cool! Looking forward to the pics!!
#3 Cat385B ONLINE
    HAZMAT CAT
  • 13,138 Thanks
  • 9,617 posts
Posted September 17, 2012 - 05:51 PM
Goodness, I hope that plows in good shape. That 1010 is a lot of tractor.
#4 KC9KAS OFFLINE
KC9KAS
  • 5,200 Thanks
  • 4,584 posts
Posted September 17, 2012 - 05:52 PM
The rain should make the plowing a little easier....as long as it doesn't get TOO wet!
#5 Michiganmobileman OFFLINE
Posted September 17, 2012 - 05:55 PM
Pics are a must :)
Edited by Michiganmobileman, September 17, 2012 - 07:28 PM.
#6 olcowhand OFFLINE
  • 38,791 Thanks
  • 30,696 posts
Posted September 17, 2012 - 06:29 PM
OK, here's the MF1010 with plow. Still have the deck under, but of course it will be coming off.
Here's showing how I rough built this adapter.
Massey "2055" with plow attached & ready.
Bush Hog "Hogzilla" diesel with plow & ready (other than needs a good bath).
And my 4th plow that B10dave from Canada may need to borrow for plow day.
#7 KennyP ONLINE
  • 35,065 Thanks
  • 44,083 posts
Posted September 18, 2012 - 04:54 AM
Looks like you're about set up there, Daniel! I bet you guys are going the have a great time!
