Welded Vs Non-welded Oil Pan - Pics Please?
11 replies to this topic
#1 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted September 16, 2012 - 09:29 AM
My LGT165 has the welded-in oil pan/front axle mount. As I understand, some were welded (like mine) and the later ones were bolted (?) in somehow.
In another thread I was trying to match another kohler that I had to my pan - but it is the wrong engine case size, so will have to wait for the original motor being rebuilt to get it going again. :mecry:
Anyway, if the pan were not welded in, I would have many engine choices (including "upgrading" to a Kohler twin that I have laying around). Got me to thinking, what's the setup for the newer non-welded models? At this point, is too much trouble to cut out and fab a new setup - I have the new parts for the engine, just having to ship parts off to have the machine work done - no local shop anymore. Just have to be patient :p
So, just for knowledge sake, can somebody show me/tell me how the engine mounts/attaches to the frame in the later models? Is the front axle mount still cast into the oil pan, or is it a seperate item?
For reference, here are a couple pictures of how the weld-in model mounts - I took everything off so you could see it clearly :laughingteeth:
IMG00274-20120228-1652.jpg IMG00342-20120428-1745.jpg IMG00391-20120502-1224.jpg
#2 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted September 16, 2012 - 09:55 AM
My 165 is the bolt-in engine. I'll have to look through my pics and see it I have any to post of that area. It's been a while since I looked under there, but the front axle mount is welded into the frame.
Here's a couple I found so far!
#3 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted September 16, 2012 - 10:54 AM
I happened to have a pic of the axle.
These are heavy built front axles... The angle iron looks like it is about 3x3 by1/4 thick !!
#4 CASENUT OFFLINE
  • 505 Thanks
Posted September 16, 2012 - 11:35 AM
Swapping a motor wouldn't be difficult...if you have access to a plasma cutter...just make sure the driveshaft stays in pretty close proximity to where it is now...
Edited by NutCASE, September 16, 2012 - 11:35 AM.
#5 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,004 Thanks
  • 4,414 posts
Posted September 16, 2012 - 03:49 PM
Here you can see the motor mounts well (LGT-145), Logan doing the work.
#6 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted September 16, 2012 - 04:02 PM
Great pic of both the helper and the frame!
#7 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,004 Thanks
  • 4,414 posts
Posted September 16, 2012 - 04:23 PM
Thanks KennyP, I looked close at your pictures, looks like the 165 uses same motor mounts, but a different enging mounting plate. Mine are full length mount to mount "V" shaped brackets.
#8 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted September 16, 2012 - 05:08 PM
Mine is two piece, bolts to each side of the pan from the bottom I should have taken more pics back then!
#9 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,004 Thanks
  • 4,414 posts
Posted September 16, 2012 - 06:15 PM
Mine are 2 piece too, I guess a different configuration. Each side bolts to the motor mounts, and then angles to bolt to the bottom of the motor.
#10 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted September 16, 2012 - 06:50 PM
Sounds the same to me. Does it look like this?
#11 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted September 16, 2012 - 06:57 PM
Thanks guys!!! Much easier to see it than explain it!
So the engine mounts to a cradle (2 pieces) and then the cradle mounts onto the engine mounts. AND the front axle mount is a seperate piece that mounts under the frame tubes. Looks like there would be a lot of flexibility engine wise as long as you can make a cradle to match the mount points. Worst case, you could even move them if needed.
Nutcase - I didn't figure it would be to difficult to switch engines - just didn't know how the factory mounted them. Looks pretty straight forward. Actually, looks like the hardest thing is getting the old pan out without damaging it or the tubes.
But the list of waiting projects is pretty long already, so just gonna resurrect the original setup (for now...). If I really like the tractor, I may switch it out "someday"..... Most of my other gts have been Deeres, but I like the way this Ford is put together. Hopefully will have it together and running for the spring season.
#12 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted September 16, 2012 - 07:52 PM
Closed sided rigs are all the same from the 100-165 . They all used a 2 piece mounting plates. The engine blocks are interchangeable from old to new or visa versa.
