Having Computer Problems
6 replies to this topic
#1 jms180 ONLINE
jms180
  • 1,639 Thanks
  • 1,626 posts
Posted September 15, 2012 - 05:45 PM
When I try to shut down it just keeps running with message displaying logging off. It is a Dell running windows 7. It works ok just will not log off.
#2 HDWildBill OFFLINE
  • 8,978 Thanks
Posted September 15, 2012 - 06:11 PM
Did Dell install windows 7? If you are sure your system is clean, no Malware or spyware, the check on their website to see if there are any updates especially firmware.
if it is still under warranty then call their customer support.
  • jms180 said thank you
#3 jms180 ONLINE
jms180
  • 1,639 Thanks
  • 1,626 posts
Posted September 15, 2012 - 07:02 PM
Thanks Bill I will check
#4 Arti OFFLINE
Arti
  • 1,366 Thanks
  • 990 posts
Posted September 15, 2012 - 07:24 PM
If it is the first time you should be able to pull the plug and then restart the computer.. If this is a laptop you also need to remove the battery and pull the plug.
If this continues to be a problem then reinstalling the operating system will likely be necessary.
Also if you have a memory card from a camera plugged in sometimes that will cause this.
#5 lyall ONLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted September 15, 2012 - 11:06 PM
from the command prompt you can type one of the follow or you can make a batch file for each command
shutdown -r this restarts you pc
shutdown -s this will shuts down your pc
shutdown -l this will logoff your pc
shutdown -t xx the xx are second that you want the pc to wait till shutdown/restart/logoff
shutdown -i gives you a dialog box to fill in what function you want to use
shutdown -a aborts the previous shutdown command....very handy
shutdown -t 0 -r -f
use this whenever I want to force an immediate reboot
if you need to know more about this Google "
windows logoff command"
I have used several of these commands to reboot, log off and shut down and several pcs at work
#6 jms180 ONLINE
jms180
  • 1,639 Thanks
  • 1,626 posts
Posted September 16, 2012 - 06:02 PM
Thanks guys my wife & I got the problem figured out. Its was a conflict between windows firewall and the antivirus running. We turned off windows firewall. It shuts down ok now thanks again for the help.
#7 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,498 posts
Posted September 19, 2012 - 09:50 AM
Do you have some sort of firewall in the antivirus? Which one are you using?
