Hb112 Seat Not Closing Properly
allis
9 replies to this topic
  • 2,325 Thanks
  • 1,496 posts
Posted September 13, 2012 - 07:53 PM
So, while I was removing the crude from around the transmission & cooler, I noticed a shinny spot. Made me wonder what was rubbing. When I lowered the seat, I saw that the seat sits on the tranny cooler. Is that the was they are designed? If not, can anyone tell from the pictures what is assembled wrong?
Edited by New.Canadian.DB.Owner, September 14, 2012 - 06:50 PM.
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted September 13, 2012 - 09:48 PM
Check the front of the fender pan, where it sits about the tunnel. There should be rubber stoppers below the latches.
#3 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted September 14, 2012 - 09:08 AM
I had a look and the rubber stoppers are still there. Maybe they are too short? Any other ideas?
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted September 15, 2012 - 08:00 AM
Are there any breaks on the weld seams anywhere? Right side seat bolts don't look to be the issue...
#5 Michiganmobileman OFFLINE
Posted September 15, 2012 - 08:08 AM
Your last picture looks like a gap in the weld to the support. May be letting the seat sag just a little.
edit
add pic
Edited by Michiganmobileman, September 15, 2012 - 08:19 AM.
#6 Enginerod OFFLINE
Enginerod
  • 230 Thanks
  • 286 posts
Posted September 16, 2012 - 06:58 AM
I agree with michiganmobileman, I had a Simplicity 3314 that had a similar problem, mine had been backed into something or run into and tweaked the seat pan a little.You are going to have to find a way to close the gap between the hinge and seat pan and tack weld it.
  • Michiganmobileman and New.Canadian.DB.Owner have said thanks
#7 Michiganmobileman OFFLINE
Posted September 16, 2012 - 07:29 AM
You should be able to remove the seat and then with some blocks and bar clamps (not saying a BFH might be needed too) pull that back together and reweld.
#8 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted September 16, 2012 - 06:35 PM
Thank you for the input! I had a look & yes, both welds have failed. I will try to sort that out over the next (???) couple of days.
#9 Enginerod OFFLINE
Enginerod
  • 230 Thanks
  • 286 posts
Posted September 16, 2012 - 06:40 PM
You may be surprised how much force it takes to bend that seat pan back into shape. I know I was.
#10 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted December 03, 2012 - 06:22 PM
I final had some time to look at this issue again, now that I have the tractor in the shop to change the seals. The front seat support bracket is also slightly bent. There is also a crack in the frame that will need some attention. At least I have something to try out the repaired welder on now ...
Also tagged with one or more of these keywords: allis
