Trying to re-pulley
4 replies to this topic
#1 MH81 OFFLINE
Posted July 29, 2010 - 09:11 PM
I've had a thread on the Craftsman forum about trying to find a new pulley for a splined shaft on my tractor. pictures 1/2 way down. Anyways, I have about given up :wallbanging:on the right part existing & will have to modify the shaft. I'll really have to gut the transmission to take the shaft out to put in a keyway. Any ideas? The spline is HARD stuff. I thought about a sleeve/compression pulley, but I can't find one with enough offset (see picture). Any thoughts on a set-screw holding up?:confuse: Kinda open to new ideas on this one. Thanks in advance.
#2 olcowhand ONLINE
  • 41,086 Thanks
  • 31,402 posts
Posted July 29, 2010 - 09:40 PM
On those really hard shafts, the best way to cut a keyway is with a stone, like a dremel cutoff wheel. If there's room to use a larger diameter stone, then an air cutoff tool works well. I've cut keyways in hardened shafts this way a few times & always held up well. Just requires taking your time to be sure all is correct depth & width. If things ger a bit off kilter, you can make a key to fit.
#3 MH81 OFFLINE
Posted August 08, 2010 - 10:25 PM
I took all the worn-out 3" cutoff wheels for my air grinder & made them the same, right size. Blade is just shy of 1/8" Slow & steady...Worked great.
#4 olcowhand ONLINE
  • 41,086 Thanks
  • 31,402 posts
Posted August 09, 2010 - 03:21 PM
So is she rolling under power again yet?
#5 MH81 OFFLINE
Posted August 09, 2010 - 03:58 PM
I did try for some video last night, too dark (posted anyways on original thread - see above) Will try for some better footage after work.
