Converting A Vertical Shaft V Twin Kohler To Horizontal Shaft?
18 replies to this topic
#16 CubCadetPulling OFFLINE
CubCadetPulling
  • 3 Thanks
  • 2 posts
Posted December 30, 2012 - 03:29 PM
How to Convert a Kohler Command V-Twin Vertical Shaft Engine into a Horizontal Shaft -
  • Drill the oil drain-back holes in the corners of the cylinder heads near the valve train so the oil can drain back down in the oil pan.
  • The oil pump must be changed (pickup tubes are different).
  • The vertical shaft engine has no horizontal mounting holes on the block. (They are on the sump cover.) So a couple of L-shaped engine mounting plates must be fabricated to convert the block into a horizontal shaft and mount the engine in the tractor frame.
  • Various holes in the block must be blocked off (drain holes are different, etc).
  • Everything else on the engine should work with no modifications. The PTO end of the crankshaft will be a little long, being it's made for a vertical shaft engine. But it'll still work just fine in the horizontal position.
  • skyrydr2 said thank you
#17 Texas Deere and Horse OFFLINE
  • 14,900 Thanks
  • 15,518 posts
Posted December 30, 2012 - 03:55 PM
Kieth, I uploaded a video for a member here that has a conversion of a Kohler Command 18.
Here is the link,
I will look for the thread.
  • Toolpartzman said thank you
#18 Texas Deere and Horse OFFLINE
  • 14,900 Thanks
  • 15,518 posts
Posted December 30, 2012 - 03:59 PM
Here is the thread,
http://gardentractor...al/#entry146160
#19 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted December 31, 2012 - 06:14 PM
Thanks CCP that was what I was thinking but wasn't sure. I have access to some serious machining equipment so I should be able to get this 25 hp engine cranking horizontally pretty easily. Nice !!!!
