Wisconsin Tf
27 replies to this topic
#16 MFDAC OFFLINE
MFDAC
  • 3,215 Thanks
  • 1,586 posts
Posted April 17, 2015 - 07:03 PM
Always Great seeing these Wisconsin's brought back from the dead.
If you need any parts help or literature let me know
Thanks! I was hoping to see a pic of a nicer engine ID tag and find out an approximate weight of this engine. I do know the tube or hose between the air filter and carb is missing and may need to be a formed one. I really don't know if anything else is missing yet.
DAC
#17 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted April 17, 2015 - 09:55 PM
That's 14.6hp. What's interesting to me is that the THD made 16.8hp with a bore of 3 1/4 with stroke of 3 1/4, while the TJD made 18.2hp with a 3 1/4 bore and a shorter 3" stroke.
Shorter stroke makes more HP...
#18 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,352 Thanks
  • 4,961 posts
Posted April 18, 2015 - 08:43 AM
I don't think a starter/generator combo will have enough umph to spin that engine.
For the breather tube on mine I went to O'Reillys and and got a heat riser tube for a car or pickup. Think it was about $2.
It looks like aluminum foil and is flexible so you can put the offset into it to make it fit.  I got the idea because its the same as the heat riser [from the heat shield on the exhaust manifold - to the air breather] on my GMC Suburban.   Just tell them what diameter you need.
Its a snug enough fit it stays put.  I just idle around at shows and parades with mine.  If it was a working engine or in a dusty environment I'd use a generac radiator hose with the correct offset shape, cut it to desired length, and put clamps on the ends.
  • MFDAC said thank you
#19 MFDAC OFFLINE
MFDAC
  • 3,215 Thanks
  • 1,586 posts
Posted April 19, 2015 - 09:03 PM
Thanks Kris, great idea about the heat riser tube! I know exactly what you mean and think I have a couple of used ones around here.
I may use a car starter for an electric setup then.
DAC
  • Gtractor said thank you
#20 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted April 20, 2015 - 08:10 AM
No. Just revs up faster.
#21 jtrojek OFFLINE
jtrojek
  • 1,132 Thanks
  • 580 posts
Posted April 20, 2015 - 12:32 PM
Shaw R12T used them (came with either a TF or TE)
#22 MFDAC OFFLINE
MFDAC
  • 3,215 Thanks
  • 1,586 posts
Posted April 22, 2015 - 09:38 PM
Sure would like to see a pic if you have one!
DAC
#23 jtrojek OFFLINE
jtrojek
  • 1,132 Thanks
  • 580 posts
Posted April 23, 2015 - 10:36 AM
DAC
Well, here's a picture of my old R12T with a Wisconsin TE on it.  I've seen a few of them with the TFs before, but don't have my own picture of one, I'm afraid.  Instead, I do have a Shaw Catalog on my website that mentions the R12T with a Wisconsin TF.  Here's a link to the brochure:
http://static1.squar...talog No 23.pdf
Check on page six.  Here's a picture of my old Shaw with the TE:
#24 MFDAC OFFLINE
MFDAC
  • 3,215 Thanks
  • 1,586 posts
Posted April 23, 2015 - 06:53 PM
Thanks for the download and pic! Very cool stuff. I bookmarked the website too, will look more asap.
DAC
#25 Esfoder OFFLINE
Esfoder
  • 1 Thanks
  • 2 posts
Posted July 29, 2015 - 07:26 AM
I have a Gibson SD 2 with the Wisconsin TF engine on it. I'll try to post some pics of it later.
#26 oldiron1 OFFLINE
oldiron1
  • 423 Thanks
  • 268 posts
Posted August 24, 2015 - 09:14 PM
I'd love to see a 2 cylinder Gibson!
I have a 1951 TF powered Shaw R12T I could post a couple pictures of if you'd like.
Thanks, Rob
#27 Esfoder OFFLINE
Esfoder
  • 1 Thanks
  • 2 posts
Posted August 28, 2015 - 01:17 PM
That would be cool
#28 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,342 Thanks
  • 9,800 posts
Posted August 28, 2015 - 04:05 PM
They don't seem to mention the fact that the TJD had a different firing arraignment. The other twins had pistons that went up and down together. The TJD pistons operated alternately. Possibly, could this give more HP?
