Vote for Tractor of the Month
Aftermarket Cooling On Case Tractor
This topic has been archived. This means that you cannot reply to this topic.
7 replies to this topic
#1 philips100 OFFLINE
philips100
  • 72 Thanks
  • 82 posts
Posted September 10, 2012 - 12:31 AM
Check out the cooling system. Is it a dealer option or an aftermarket item? :>)
Case garden tractor - $1500 (Sweetwater)
Date: 2012-09-09, 11:24AM EDT
Reply to:see below
case model 60 garden tractor. 14hp kholer engine. 3point hydrolic lift. Great shape.
call 423-519-6513
#2 mjodrey OFFLINE
  • 2,345 Thanks
Posted September 10, 2012 - 04:32 AM
I would have to say not factory.But just because I have not seen one,doesn't mean I'm right though.
#3 KennyP OFFLINE
  • 29,556 Thanks
  • 40,533 posts
Posted September 10, 2012 - 05:18 AM
There's probably a few tractors out there that could use that option! Might be a real good idea for the winter with a cab on, push a bit more warmth into the cab.
#4 JDBrian OFFLINE
  • 9,591 Thanks
Posted September 10, 2012 - 05:50 AM
That makes the tractor looks like it has a face with the nose being the blower! Somehow I don't think that's a factory option but it would help to remove all that heat from the engine and pump.
#5 HowardsMF155 OFFLINE
  • 2,700 Thanks
  • 2,917 posts
Posted September 10, 2012 - 06:44 AM
I doubt the factory would engineer a fan that seviced only a small area of the radiator. I think that is someone's home brew.
#6 Gtractor ONLINE
Gtractor
    The Tractor Hoarder
  • 7,029 Thanks
  • 4,078 posts
Posted September 10, 2012 - 09:19 AM
All I keep thinking is that poor Sears in the background. :(
I suppose the plactic fan blade gave up the ghost and they already had the fan laying around so it was a zero dollar fix. I've thought about doing that to my air cooled four wheeler because some farm chores are at such slow speeds that the engine gets very hot.
#7 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,363 Thanks
  • 2,496 posts
Posted September 10, 2012 - 10:14 AM
I agree it is not factory. I do know it gets real hot under the hood. Looks a little strange, but would like to know if it helps.
#8 olcowhand ONLINE
  • 36,219 Thanks
  • 29,984 posts
Posted September 10, 2012 - 10:19 AM
I'd say the hydraulic cooling fan blades all broke out.....and after all, he had this here fan laying there! :smilewink:
