3 Point Missing Adjustable Side Link
6 replies to this topic
#1 AV430 OFFLINE
AV430
  • 53 Thanks
  • 130 posts
Posted September 09, 2012 - 09:22 PM
Is there a substitute other than the factory adjustable side link for our 3 point hitches? Also, where could I get one, E-bay? Thanks
#2 Alc OFFLINE
  • 6,886 Thanks
  • 7,461 posts
Posted September 10, 2012 - 05:44 AM
Can't really help you out on where to get those arms , I can give you some pictures of mine if that would help , Al
#3 KennyP ONLINE
  • 38,385 Thanks
  • 45,935 posts
Posted September 10, 2012 - 07:20 AM
Try looking here for something. I came across this some time back. Do you have TSC close by? They may have something that would work.
#4 mjodrey OFFLINE
  • 2,356 Thanks
Posted September 10, 2012 - 07:27 AM
I wish I could help you,but I can't.
#5 AV430 OFFLINE
AV430
  • 53 Thanks
  • 130 posts
Posted September 10, 2012 - 12:41 PM
Thanks guys for all your help. Kenny, awesome link! Thanks! I do have TSC nearby so I'll check them.
Edited by AV430, September 10, 2012 - 12:43 PM.
#6 glgrumpy OFFLINE
  • 8,612 Thanks
  • 7,920 posts
Posted September 10, 2012 - 05:01 PM
I built some once. Used rectangle tubeing for the lower link, cutting off one small side to make U-shape. Steiners or maybe others have just the ball in Cat O size that is used in ends of arms. Use that same ball, same as PK and weld on two rod studs to it's side, just like they did. Thinking I tack welde big nut on that and used 5/8" threaded rod then to screw thru it and down to U-shaped Link?? Can't seem to recall for sure. Had to make some flat stock welded to a nut for handles at top to adjust. Maybe I have picture still??
#7 KennyP ONLINE
  • 38,385 Thanks
  • 45,935 posts
Posted September 11, 2012 - 08:30 AM
Good ideas in that post, GL! Thanks for sharing, I had no idea what the set up looked like.
