Welding Table
20 replies to this topic
#16 caseguy OFFLINE
Posted September 10, 2012 - 08:28 AM
Are you going to mount a vise on it ?
That is my intention, but I need to find a good, old, sturdy one first.
Sent from my ADR6350 using Tapatalk 2
#17 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted September 10, 2012 - 09:05 AM
That's a good solid table, that will work you to wear it out!! As for the anvil the table will be too high for an anvil. You will want a lower stand for it anyway to get the hammer level with the top of the anvil(so all the energy is transferred to the item your working). if the anvil is too high you will waste a lot of energy and it can cause ergonomic issues(like carpel tunnel and will transfer shock to your arms). So just make a stand lower for the anvil as your next project. I'm sure you will find it more useful by not cluttering up your table too. A blacksmith forum will give you a wealth of info on set up height for an anvil and of course it has a lot to do with your stature. I think you will find the anvil height(top face) works best at a height roughly half way between the elbow and wrist standing straight up.
Edited by JD DANNELS, September 10, 2012 - 09:16 AM.
  • caseguy and IamSherwood have said thanks
#18 Cvans OFFLINE
  • 5,028 Thanks
  • 5,365 posts
Posted September 10, 2012 - 09:40 PM
That is one honkin heavy table. Nice job on the fabrication.
  • caseguy said thank you
#19 caseguy OFFLINE
Posted September 11, 2012 - 09:11 PM
Are you going to drill and tap in a few locations, so you can secure stops, or hold down clamps?
Sorry that I didn't answer this sooner Will. Somehow this particular post slipped past the radar :confuse: There are already several holes with threads in them, but they're like 1" bolt holes! They will need to be cleaned out, but I believe that whatever I bolt down with them they won't go ANYWHERE! I will also have to drill and tap some for the vise. (when I find a good one that I can afford) I guess to answer your question...I have the means and the ability if the need should arise. It's a great idea and I hadn't thought of doing so, but now if the situation presents, I'll know the solution straight away! Thanks for the suggestion!
  • IamSherwood said thank you
#20 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted September 12, 2012 - 08:15 AM
anybody ever mount the vise on the side in middle of the table? try it you'll like in Christ
#21 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,505 Thanks
  • 1,078 posts
Posted October 09, 2012 - 02:41 PM
That's a good STRONG table!! Very good job!!
Mike
