Beginnings Of My First "puller".
19 replies to this topic
#16 MH81 OFFLINE
  • 29,978 Thanks
Posted September 11, 2012 - 06:36 PM
Dane, That'll make a good looking Puller. Those Speedex will really put the motor to the wheels while pulling stuff around the yard, I hope it does equally well for you on the track.
  • Dane in PA said thank you
#17 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted September 11, 2012 - 09:28 PM
Next is to mount the engine (After I put it back together...). I plan to use something like mudflap material to absorb vibration from the motor through the frame. Then will be to make the wheelie bars and test it to see how it does without weight, and to see where it needs weight.
#18 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted September 12, 2012 - 04:54 PM
I need to get the rest of the parts together before I can do anything major. I'm finishing up with the motor, but need the hood to do the wiring and governor adjustments.
#19 stormscrambler OFFLINE
stormscrambler
  • 1 Thanks
  • 7 posts
Posted October 23, 2012 - 09:39 PM
nice tractor, i wish there was more of those out here in cali, i ended up with a 64 power king tractor and it is nice cause it is complete but it needs some work
#20 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted October 28, 2012 - 07:55 PM
I got the engine mounted, but need to work on some things with the trans, as some of the mounting bolts are loose. I may end up just getting this one together and selling it to buy a snow plow for the 140...
