'84 Power King 1217 Electric Deck Lift
6 replies to this topic
#1 clamb2411 OFFLINE
clamb2411
  • 2 posts
Posted September 08, 2012 - 04:13 PM
I recently picked up an 1217 wi a 48" deck and electric lift.
The lift linkage appears to have recently lots a few parts. At first I thought it might just be the turnbuckle connecting the chain to the arm, but that's clearly not right. Does anyone have a diagram showing how the electric lift arms (welded to a shaft which rotates) connect to the deck? I found a large pin in the yard, so I suspect something is missing.
Thanks!!
Chris
#2 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted September 08, 2012 - 05:35 PM
Welcome to the site Chris! I don't know much about the plastic power kings. Somebody on here might be able to tell you exactly what you need!
#3 glgrumpy OFFLINE
  • 8,609 Thanks
  • 7,915 posts
Posted September 08, 2012 - 08:18 PM
I have a drive with info if I can find it. the info that is. Not sure if electric was option or standard might make a diff. I'll see what I can find on it, BUT, how to save and remove might be a diff story, ha!
#4 glgrumpy OFFLINE
  • 8,609 Thanks
  • 7,915 posts
Posted September 09, 2012 - 01:46 AM
I loaded info in my photos. I then have scanned them. Not much info, just install and pictures. Not much to it. Also have mower mounting instructions I could get if that is more helpful. These appear pretty simple.
#5 mjodrey OFFLINE
Posted September 09, 2012 - 04:25 AM
Chris,welcome to the forum.Glad to have you with us.
#6 clamb2411 OFFLINE
clamb2411
  • 2 posts
Posted September 09, 2012 - 02:57 PM
Thanks guys for the quick response and welcomes!! glgrumpy, it looks like what I'll need are the mower mounting instruction. I think there's some kind of linkage bit missing but I don't know what.
Thanks again!
Chris
#7 glgrumpy OFFLINE
  • 8,609 Thanks
  • 7,915 posts
Posted September 10, 2012 - 10:13 PM
Let's try this again! Print is hard to read on instructions, hope you can blow them up somehow?Couple diff deck sizes and mounts for them. I picked what I thought would be good example.
