Front Axel Play
2 replies to this topic
#1 bobp OFFLINE
  • 15 posts
Posted September 08, 2012 - 08:33 AM
I have a cub original that has a lot of side to side play in the front axel. Im not sure if the pin is worn or the actual axel is worn. Is there a fix for this? Maybe some sort of sleeve or shims? thanks.
#2 bgkid2966 OFFLINE
  • 1,411 Thanks
  • 1,331 posts
Posted September 08, 2012 - 08:53 AM
The axle pin could be worn, this is common if it is not greased and I am not sure if an original has a fitting or not. New pins are probably still available if needed. Hopefully your axle is not worn. I am not sure about bushings for the axle, but a maintenance machine shop could bore it and bush it for you.
  • bobp said thank you
#3 mjodrey OFFLINE
  • 2,356 Thanks
Posted September 08, 2012 - 09:22 AM
It is most likely the pin.It it is the axle,it can be fixed in a couple of ways.You could bore it and put in a bushing,or weld up the hole and redrill to proper size.
