Mowing Deck Question
15 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 04, 2012 - 04:08 PM
on my yard machine that i picked up not long ago, i went out today to remove the blades so i could sharpin them they wouldnt losen up. what the best way to losen up blades with the deck still attached to the tractor?
#2 olcowhand ONLINE
  • 41,092 Thanks
  • 31,402 posts
Posted September 04, 2012 - 04:14 PM
Air impact wrench! The only way in my book!
#3 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted September 04, 2012 - 04:49 PM
Yup, impact works best. If it's still stubborn, heat the nut up with a propane torch.
If you lack air tools, heat the nut with a propane torch, then put a socket with a solid bar on it and hit the bar with a largish hammer.
Also, an extensive vocabulary of words your mother told you not to use seems to come in handy.
  • backwoods said thank you
#4 HDWildBill OFFLINE
  • 8,975 Thanks
Posted September 04, 2012 - 05:17 PM
Ditto on the air impact wrench. If you don't have the air tools then maybe some PB Blaster then like the Rev said a propane torch on the nut.
#5 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted September 04, 2012 - 07:56 PM
Ditto on the nasty words.
Wedge a piece of 2x4 between the blade and the deck to keep it from spinning. You just got to find just the right spot and just the right piece of wood.
#6 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 04, 2012 - 08:26 PM
ill give it another try tomorrow after classes
#7 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted September 04, 2012 - 08:36 PM
Once you have them loose, do yourself a favor and apply some anti-seize to the threads. It will make it easier to remove the next time.
#8 Salatino OFFLINE
Salatino
  • 29 Thanks
  • 188 posts
Posted September 08, 2012 - 11:24 AM
oh yeah def. the impact , or like they said pb , heat &cheater bar
#9 HDWildBill OFFLINE
  • 8,975 Thanks
Posted September 08, 2012 - 12:21 PM
Backwoods did you ever get the blades off?
#10 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 10, 2012 - 07:32 PM
never got the blades off, but i pulled the deck today to see what was wrong with the cutting issue and i have 3 of 4 lift arms for my deck so i need to get another one some how
#11 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted September 11, 2012 - 07:04 AM
Sure would like to see some pics of this. I have a deck off one of these and could use some inspiration on how I could adapt it to something else. It is a well built deck.
#12 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 11, 2012 - 11:26 AM
i put the deck back on Kenny what type of pics of the deck would you like the hanging system?
#13 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted September 11, 2012 - 12:47 PM
Yes, how it attaches, raises/lowers. Also, can you measure how far apart (front to rear) the hangers are on the tractor.
#14 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 13, 2012 - 09:17 AM
im missing part 4
http://www.mtdparts....S/0100919000009
also Kenny it shows how they mount
Edited by backwoods, September 13, 2012 - 09:21 AM.
#15 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted September 13, 2012 - 09:21 AM
Link isn't working!
