My Electrolysis Set Up
18 replies to this topic
#16 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted September 04, 2012 - 08:38 PM
Moved it outside this afternoon, and got a charger for the battery. Then discovered my wire rings had been eaten up, will have to go get some rebar and try again! :mad2:
#17 MH81 OFFLINE
Posted September 04, 2012 - 09:17 PM
You will get more line of sight with sheet tin or something like that. also more surface area.
It is harder to keep your part from touching tho. just be aware & safe.
#18 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted September 04, 2012 - 09:44 PM
Yes go with something besides rebar- takes too long to clean up. I started with rebar and now use flat metal. Sounds like you got it going!
  • herbfarts said thank you
#19 KennyP ONLINE
  • 37,536 Thanks
  • 45,524 posts
Posted September 05, 2012 - 04:03 AM
I used rebar on mine. I just swap the connections and hang a sacrificial piece in. Loosens the crud on the rebar so if cleans off very easily.
