Looking For A Cheap Way To Remove Paint
26 replies to this topic
#1 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted September 03, 2012 - 07:41 AM
I would like to strip my B12's fenders today,and I need a cheap method of doing it. Any and all advice is appreciated, Thanks!
  • goodnews said thank you
#2 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted September 03, 2012 - 07:46 AM
Electrolysis .... For those of us that don't have a sand blasting cabinet.
My first one was a large plastic trash can and rebar ......flat sheet steel is better than rebar if you go this route. Search electrolysis and you will find Daniel's article on " how too"
Edited by sacsr, September 03, 2012 - 07:48 AM.
  • Toolpartzman, goodnews and bigcountry48 have said thanks
#3 MH81 OFFLINE
Posted September 03, 2012 - 07:50 AM
I've heard several ways that it can be done on the cheap.
The one I've used is electrolysis, but it's not a fast process. 24 hours in the tank while doing other stuff is the best way.
I've heard guys using Oven Cleaner (I asked my wife if we had any once... She just looked at me funny)
Other things I have heard guys using include
brake fluid. (Sounds messy to me.)
Molasses (this is a long term process, and it sounds messy)
Lye water (dangerous and long time in) (never did hear results, now that I think of it)
Probably the fastest would be the oven cleaner and good old fashioned elbow grease...
The only one I can attest to is the electrolysis. It does work if you wait long enough and have all the stuff around to do it.
Please let us know what you used and how it worked.
  • sacsr, herbfarts and bigcountry48 have said thanks
#4 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted September 03, 2012 - 07:53 AM
I too have heard oven cleaner would do the job. If you go that route let us know how it works out. Good luck!
  • MH81 and bigcountry48 have said thanks
#5 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
:iagree: By far --Electrolysis---------Cheaper, Better final finish, will reach spots a sander won't, No dust and leaves less prep work for the new paint
  • KennyP, sacsr and bigcountry48 have said thanks
#6 Jack OFFLINE
Jack
  • 1,309 Thanks
  • 861 posts
Posted September 03, 2012 - 08:00 AM
If they are off the tractor I would think a good quality paint stripper would work pretty well.
Jack..
  • bigcountry48 said thank you
#7 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Where do I find the article on electolysis, I'm having trouble finding it.
#8 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted September 03, 2012 - 08:06 AM
Try this http://gardentractor...lectrolysis-r59
  • MH81, herbfarts and bigcountry48 have said thanks
#9 MH81 OFFLINE
It can be found here:
  • herbfarts and bigcountry48 have said thanks
#10 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted September 03, 2012 - 08:19 AM
So let me get this straight, I have a medal ring at the top connected to one at the bottom of a plastic bucket, and connect the positive end of a dumb battery charger to it. Then I put the fender in with the negative pole to it, plug it in and wait 24 hours. With baking soda in the water.
#11 olcowhand ONLINE
  • 42,439 Thanks
  • 31,817 posts
Posted September 03, 2012 - 08:36 AM
Yep!
#12 KennyP ONLINE
  • 40,183 Thanks
  • 46,794 posts
Posted September 03, 2012 - 08:57 AM
Just be sure to keep the part suspended in the solution. And you may have to change the angle of the part to get all surfaces. This works on a 'line-of-sight' principal. You should see small bubbles coming off the part if all is working correctly. I usually hook a battery in line with the charger.
  • herbfarts said thank you
#13 MH81 OFFLINE
Posted September 03, 2012 - 09:06 AM
I found washing soda to work a little better, but if you don't have any, baking will do.
#14 wawcub47 OFFLINE
wawcub47
  • 68 Thanks
  • 167 posts
Posted September 03, 2012 - 10:03 AM
If you use oven cleaner,BE SURE to wear some rubber kitchen gloves and rinse off the residue with water. oven cleaner Will burn your skin and be sure to wear eye protection. ive used it alot and had good results.
  • sacsr and goodnews have said thanks
#15 KC9KAS ONLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted September 03, 2012 - 10:20 AM
I agree....we used oven cleaner on the outdoor gas grill, and that oven cleaner is some bad stuff!
I purchased my washing soda from Rural King.
