140 H3
17 replies to this topic
#1 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted September 02, 2012 - 05:12 PM
Got started stripping my 140 going to try to make it look & run like new. So far not to much damage except rust. If you look at the one picture you'll see a new hydro hose. I put that on when I first got it. Someone was already at that hose as you can see the cut in the frame. I don't believe that was a factoryImageUploadedByTapatalk1346623901.910836.jpg ImageUploadedByTapatalk1346623912.325660.jpg ImageUploadedByTapatalk1346623922.450961.jpg ImageUploadedByTapatalk1346623937.995585.jpg ImageUploadedByTapatalk1346623950.982622.jpg cut.
#2 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted September 02, 2012 - 06:14 PM
I think your right about it not being a factory cut, unless someone decided to do a little work
during the factory x-mas party, booze was allow at parties back then :smilewink:
P.S. looking forward to the after pictures :thumbs:
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,277 Thanks
  • 9,768 posts
Posted September 02, 2012 - 07:00 PM
Is that the only way to get at it???
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted September 02, 2012 - 07:03 PM
Definitely not factory but after having worked on the later but very similar 314 I can understand why it was done. Some stuff is pretty near impossible to get at on those tractors.
  • 14,792 Thanks
  • 15,492 posts
Posted September 02, 2012 - 09:00 PM
You have to get under the tractor to get to that hose with a back up wrench, someone was being lazy. IMHO
Sorry they butchered your frame like that.
#6 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted September 02, 2012 - 10:16 PM
Well got it cleaned up. Lot of old grease oil & dirt. Now just to get all the rust cleaned up. ImageUploadedByTapatalk1346641515.952014.jpg ImageUploadedByTapatalk1346641528.346041.jpg ImageUploadedByTapatalk1346641540.227062.jpg
Got it up so I can clean the underside. Only thing I found was rearend is leaking. Hope to get more pictures going to pull it outside & give it a wash. Then to the rust. Any ideas?
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted September 03, 2012 - 05:49 AM
Nice looking 140. Doesn't look that rusty to me. The vent / gauge pipe is a source of many leaks on the 300 series. I'm not sure that the 140 is set up the same way. There must be a vent though. It's near the top of the rear end on the left side. If you have it tipped up like that it may leak from there.
  • fishman said thank you
#8 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted September 04, 2012 - 05:23 PM
Well got frame painted. Started cleaning other parts was the original color all green except for motor being black & wheels yellow? Also when I got the 140 it didn't have a grill. Is it the same as 110's?
#9 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,277 Thanks
  • 9,768 posts
Posted September 04, 2012 - 07:21 PM
Did you repair the cut out in the frame?
#10 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted September 04, 2012 - 08:05 PM
It appears that your 140 has the drum brakes, and the front wheels are the bolt on type. This would put the year of your tractor between 1971-1974. You will need the thin grille that snaps in between the hood supports. Yes, this same type grille is the same one used on the later 110's and 112's.
Edited by johndeereelfman, September 04, 2012 - 08:06 PM.
#11 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted September 04, 2012 - 11:00 PM
No didn't fix frame I don't think it would weaken it enough to worry about. So should I make it all green except motor and wheels. I'm hoping my son can get fenders sandblasted that will save me some work.
#12 schweitz OFFLINE
schweitz
  • 19 Thanks
  • 23 posts
Posted September 05, 2012 - 12:14 AM
Fishman, I'm looking forward to following your restoration progress. Thanks for the pics as well. Just this weekend I went 400 mi to Spokane WA to pick up a JD140 h3 with Johnson FEL, and 4 other attachments. Runs quite well but will need a lot of TLC over this winter.
We're across the continent from each other, but hope we can share some ideas as well as woes. I have friends around Lititz PA, so know a little about your state.
Lee from Salem OR
#13 Trav1s ONLINE
Trav1s
  • 3,283 Thanks
  • 4,347 posts
Posted September 05, 2012 - 06:36 AM
Check out my 120 thread for colors. The only change I made was painting the engine upper heat shield blitz black in stead of leaving it the original bare metal/silver. Engine is definitely black - some use gloss but I used Deere Blitz black which is a matte finish.
#14 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted September 05, 2012 - 09:52 AM
My 140 story is a lot like yours I keep saying its a worker not a looker but mine is sitting in garage all in pieces. And as I'm putting it back everything is getting cleaned & painted. For me no big deal I have been doing body work since I was a kid. It's the motors that give me trouble.
  • Trav1s said thank you
#15 Trav1s ONLINE
Trav1s
  • 3,283 Thanks
  • 4,347 posts
Posted September 05, 2012 - 10:40 AM
If you have any ?'s feel free to ask. I am more comfortable with the mechanical stuff than the prep stuff for paint.
