C161 Automatic
6 replies to this topic
#1 C161AMICHIGAN79 OFFLINE
C161AMICHIGAN79
  • 3 posts
Posted September 02, 2012 - 05:43 AM
C161 A Carburator. I need to rebuild my Carburator. Can anyone help me identify what kit I need.
#2 mjodrey OFFLINE
Posted September 02, 2012 - 06:11 AM
C161AMCHIGAN79, just wanted to say welcome to the forum.Glad to have you with us.
#3 KennyP OFFLINE
  • 40,061 Thanks
  • 46,736 posts
Posted September 02, 2012 - 06:39 AM
Welcome! Some of the WH folks are probably sleeping in this morning. One should pick up on this soon.
#4 Rock farmer ONLINE
Rock farmer
  • 1,224 Thanks
  • 1,245 posts
Posted September 02, 2012 - 06:40 AM
I believe that tractor should have a Kohler engine in it.
Check for a silver label somewhere on the engine.
It should have a model number and a series number.
Then go to a kholer manual to fine the proper carb number for it.
And welcome to the forum!
Joe
#5 C161AMICHIGAN79 OFFLINE
C161AMICHIGAN79
  • 3 posts
Posted September 02, 2012 - 06:53 AM
Thank you, it does have a Kohler cast iron 16 HP.I had it running and now it will only start with starting fluid. It had a very dirty fuel tank which I cleaned out, but maybe not well enough.
#6 C161AMICHIGAN79 OFFLINE
C161AMICHIGAN79
  • 3 posts
Posted September 02, 2012 - 06:56 AM
I would just like to say thank you again. My posting isn't even 2 hours old and you guys are already on it.
Les
#7 KC9KAS OFFLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted September 02, 2012 - 11:49 AM
Make sure you have a good,clean fuel filter before the fuel pump.
I put a can of SEAFOAM in my 5 gallon fuel can before I fill it with gasoline. This helps keep the lousy fuel (ethonal) fromm causing more problems.
