Difference Between Wisconson Aen And Aens Engines?
27 replies to this topic
#16 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted September 02, 2012 - 04:49 PM
:blink: Wow Ryan, I've never seen cooling fins anywhere near that Bad! :confuse: Was it living by the ocean?
Matt
#17 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted September 02, 2012 - 07:35 PM
Here is that chart.
#18 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted September 02, 2012 - 07:36 PM
Ryan, an AEN is 8.2 hp I didn't see a listing for an an AENS, Wisconsin made that engine for 1949 to 1957
www.asecc.com/data/wisconxin-models you can get a complete list of Wisconsin I.D help there
This link does not work.
#19 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted September 02, 2012 - 08:04 PM
Ryan the "S" of the AENS stood for high speed. most of the earlier Wisconsins were rated for 2600 rpm the S rating meant they were rated up to 3600 rpm. As you can tell it is tough to find a lot of info on the earlier Wisconsins. I have never seen one that rotted, Is the pic you posted showing the area at the exhaust?
#20 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted September 02, 2012 - 08:15 PM
Thanks for letting us know! I wish my engine had the ID tag so I could tell what it was. Maybe there is another difference someplace? If it runs faster there has to be a difference.
Yes, that is next to the exhaust. The pipe going to the left is the exhaust.
#21 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted September 02, 2012 - 08:24 PM
Thought so, looked a lot like the little AB I used to have. I'd have to guess that engine was run HOT a lot.
#22 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted September 02, 2012 - 08:32 PM
I think I may grind off those couple rotted fins so it is flush and does not look so jagged. This tractor will not see any real work, just start up and a little putting around so it does not sit. I will restore it.
#23 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,309 Thanks
  • 4,948 posts
Posted September 02, 2012 - 08:42 PM
You will definately want the high speed engine. Power Kings only have three speeds: slow, slower, and "is this thing moving"?
:laughingteeth:
#24 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,279 Thanks
  • 9,770 posts
Posted September 03, 2012 - 06:46 AM
:laughingteeth:
When PK switches them from 18" to 24" tires, is there a corresponding change in trans gears?
#25 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted September 03, 2012 - 07:23 AM
No, they are the same. With a Jim Dandy or Country Squire model the bull gears in the final drives are smaller, making them a little faster.
#26 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,309 Thanks
  • 4,948 posts
Posted September 03, 2012 - 09:36 AM
I think the gearing in my 1614 is 5.17 to 1. It is so slow I only use high and try not to get where I have to use reverse for very long. I have an extra tranny and thought about putting it in the tractor backwards to give me two overdrives.
#27 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted September 03, 2012 - 03:11 PM
The Wisconsins are WAY TOO HEAVY (I can't even pick one up if I wanted to.)
Ryan don't let Casey fool you ,I saw him carry some heavy stuff at the flea market lol . Is that the worse of the damaged cooling fins ? I wonder what would happen if it ran with those ,Al
#28 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,279 Thanks
  • 9,770 posts
Posted September 03, 2012 - 03:50 PM
Maybe you could build them up with a little JB Weld?
