Help With 730 Dozer Blade
6 replies to this topic
#1 Rum OFFLINE
Rum
  • 62 Thanks
  • 52 posts
Posted September 01, 2012 - 09:33 PM
I need help in mounting 730 blade to MF7. I am missing a pair of hanging straps, #16 in dozer manual part # 1 037 287 M1. They go from front bracket back to pivot tube. I want to make some if someone can give me the measurements. How long? Location and size of holes? I have the pair of compression straps but am missing the other set. I would appreciate any help you can give me.
#2 KennyP OFFLINE
  • 53174 Thanks
  • 53311 posts
Posted September 02, 2012 - 03:16 AM
Welcome to the forum! Hopefully someone will have the info you need soon!
#3 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted September 02, 2012 - 04:44 AM
Welcome to the forum.I'm sure someone will be along shortly ,who can help you.
#4 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted September 02, 2012 - 05:50 AM
Welcome to the forum. I have an MF8 but don't have the blade for it. I think they are just a straight piece of stock, if memory serves, so they should be easy to make once you get the measurements.
#5 Bud OFFLINE
Bud
  • 416 Thanks
  • 430 posts
Posted September 02, 2012 - 09:18 AM
I measured mine. It's a plain piece of flat bar. 16 1/2" long - 1 1/4" wide - 3/16" thick. the bigger hole is 3/4" (actually 25/32") and the the center of the hole is 3/4" from the end of bar. The small hole is 9/16" and the center is also 3/4" from the end of bar. About 14 15/16" from center to center of holes. I don't know if it matters but the 3/4" hole is 3/16" from one side and 1/4" from the other side.
Edited by Bud, September 02, 2012 - 10:45 AM.
  • Rum and olabster have said thanks
#6 Bud OFFLINE
Bud
  • 416 Thanks
  • 430 posts
Posted September 02, 2012 - 09:28 AM
IMGP1817.JPG here is a picture I think.
  • Rum said thank you
#7 Rum OFFLINE
Rum
  • 62 Thanks
  • 52 posts
Posted September 02, 2012 - 10:58 AM
Thank you for the measurements and picture, thats exactly what I need. I plan to make a pair of these and get the blade hooked up. I want to be ready because I live in Iowa and I know we will have snow to plow this winter.
