My New To Me Power Kings
44 replies to this topic
#31 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted September 05, 2012 - 08:02 PM
I thought I would see how well I could patch up this air cleaner. There where three cuts, only one of them bent back well enough to where I could put one bead on it and grind it flat. The other s I cut out and put a new piece of sheet metal behind it. It was hard to weld this without burning through it, resulting in some less then good looking welds. I am going to sandblast it, them put some body putty in the patches, sand it down and paint it.
I took off most of the hydraulic stuff from the '65. All that is left on there is the cylinder and the two lines. The darn link belt was tricky to figure out, but I got it off.
All of these pieces will be remade, except the L bracket. That I can save. The ends of the rods are drastically worn and have a lot of play in them. For some reason, Economy thought it would be a good idea to use nuts for the rod between the handle and pump to go through. Well, it was not the best idea! I am going to remake them with tubing that is longer to take out some of the play that it had with the nuts, and put some bushings into the tubes.
#32 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted September 05, 2012 - 08:19 PM
The engine in the '65 is serial number 4100555 and is a K321, what year would this make the engine. I already know it is not the original engine, I am just curious.
#33 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted September 05, 2012 - 09:19 PM
That is pretty thin stuff. On wire feed, the trick is to go hot (hotter than you may think), thin wire, and go fast. Do a seam for no longer than about 3-5 seconds at a time - any more and it will burn through, and then move on to a different part of the seam, allowing for a little time to cool between hits. Bondo should work well on those patches.
#34 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted September 05, 2012 - 09:27 PM
I did try to go fast, and I did only do small beads at a time, that is why the welds look so bad. I had the welder set all the way down on the lowest setting. I will have to experiment with it.
#35 Alc ONLINE
  • 6,747 Thanks
  • 7,398 posts
Posted September 06, 2012 - 05:59 AM
Ryan I ahve trouble welding thin metal too . Maybe some of the guys that do it more then us can give us some tips . I wonder if welding the air cleaner you could have used something under the patch as a "heat sink " ? Al
#36 mjodrey OFFLINE
Posted September 06, 2012 - 06:13 AM
I could have sworn I posted in this thread,but I guess not.Oh well,Ryan,congrats on your "new' machines.
#37 KennyP ONLINE
  • 37,487 Thanks
  • 45,503 posts
Posted September 06, 2012 - 06:20 AM
With thin material, do as Dean says. You'll figure how hot to go. What size wire have you got in there? Heavy wire will heat it real qiuck and burn through. I speed the wire feed up some with .030" wire and more or less spot weld it, moving to different spots so it doesn't get to hot.
#38 mjodrey OFFLINE
Posted September 06, 2012 - 06:36 AM
What I do when patching something like that,is to cut the patch and the hole the same size.Then butt weld around it.That way the patch is flush on both sides,and if you're lucky,you won't need any fill once the welds are ground down.I have done this many times,and hardly ever had to use fill.
#39 countryboy88 OFFLINE
countryboy88
  • 100 Thanks
  • 143 posts
Posted September 07, 2012 - 06:01 AM
The engine is a 1972 Ryan, here is the link were I found it. http://www.mytractor...ad.php?t=104266
Nice work on the air cleaner by the way.
#40 glgrumpy OFFLINE
  • 8,563 Thanks
  • 7,881 posts
Posted September 07, 2012 - 12:41 PM
K engine air cleaners are dime a dozen!! Swap meets and shops too I bet have lots of them. Why not just grab a diff one and be done? They might want to sell the whole cover and base, but should be cheap. Ebay even? Not worth time/effort to fix that part. My .o2 worth. Hope you are keeping that early hydraulics. Harder to get/make parts, but rarer item for PK's.
#41 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted September 07, 2012 - 05:35 PM
Last night I took off the remaining hydraulic components. And, today I got some steel rods so I can remake some of the stuff. I still need a few things.
You are absolutely right, they are a dime a dozen! But, you can always get better at welding! And I wanted to try it out and see how I did.
#42 sep OFFLINE
sep
  • 60 Thanks
  • 65 posts
Posted January 16, 2013 - 12:16 AM
Man, you have been busy!! How come I can't find any deals like this in my neighborhood? So, is this the hydraulic unit you used on the 71? Did you get the one from down the street too?
Steve
#43 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted January 17, 2013 - 10:33 PM
Steve
Yes, that is the one! The cylinder, and valve/ pump are the only parts that I ended up using on the '71; everything else I bought new or fabricated.
#44 Bob 537 OFFLINE
Bob 537
  • 68 Thanks
  • 127 posts
Posted January 18, 2013 - 11:11 AM
what ever happend with the tractor down the street?   did you buy it
#45 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted January 18, 2013 - 11:21 AM
No, I never bought the one down the road. I never even went to look at it, maybe after I get some room I will see if it is still avalable.
