Not A Good Morning....
49 replies to this topic
#1 jstiteler OFFLINE
jstiteler
  • 9 Thanks
  • 44 posts
Posted September 01, 2012 - 02:33 PM
Apparently life decided I didn't have enough going on this morning, before my daughters 3rd birthday party. So I tore one of the spindles out of my mower deck.
Does anyone know why this happened or have any suggestions to fix it?
Thanks,
Jason
#2 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted September 01, 2012 - 02:40 PM
Looks a lot like my deck, somebody had already fixed it before I bought it.
#3 shorty ONLINE
shorty
  • 5,264 Thanks
  • 5,158 posts
Posted September 01, 2012 - 02:49 PM
Is that section cast? I have used Quick Metal on cast items with decent results. I'm not sure who makes it, I had gotten it from my dad.
  • jstiteler said thank you
#4 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted September 01, 2012 - 02:58 PM
Looks like the deck was cracked the the spindle bolts pulled though.
This is how mine looked.
#5 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,961 Thanks
  • 9,609 posts
Posted September 01, 2012 - 03:11 PM
Does anyone know why this happened.....
It's usually either friction, vibration, or leverage.
#6 jstiteler OFFLINE
jstiteler
  • 9 Thanks
  • 44 posts
Posted September 01, 2012 - 03:42 PM
Thanks for the info. It is cast. I will look for some quick metal.
#7 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted September 01, 2012 - 04:00 PM
Your spindle is probably locking up, thus pulling thru the metal. Which deck is this? I may have a patch you can put in there to fix it.
#8 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted September 01, 2012 - 04:02 PM
He has the rebuild able spindles, looks like the same deck I have.
#9 jstiteler OFFLINE
jstiteler
  • 9 Thanks
  • 44 posts
Posted September 01, 2012 - 06:50 PM
481U111 stamp over the last 1 with a larger 2.
#10 olcowhand ONLINE
  • 40,313 Thanks
  • 31,161 posts
Posted September 01, 2012 - 06:56 PM
That deck is sheet steel, not cast. That will require welding to repair. Best to put in a new plate on the bottom side, as Amigatec's 3rd pic shows, then replace lost steel areas on the top side.
#11 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted September 01, 2012 - 07:09 PM
That's the same deck I have. Mine was the right spindle. If the spindle is bad and needs rebuilt, it's only about $25 a piece to do.
#12 jstiteler OFFLINE
jstiteler
  • 9 Thanks
  • 44 posts
Posted September 01, 2012 - 07:35 PM
Mine was the left. The spindle seems to be fine it moves freely just like the other two.
#13 MH81 OFFLINE
Posted September 01, 2012 - 09:16 PM
Its possible that someone hit something in the past and it weakened the deck there. Could've been decades ago... It just chose this morning to let go on you.
Good luck with your repai, If mine, I would put some metal under for reinforcement.
#14 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted September 02, 2012 - 03:25 AM
I'll get the shell out tomorrow and snap a pic. Get the bolt hole dimensions and center hole. The one I have is about 1/8" thick metal. It's just scrap metal to me, so no problem with cutting a piece out of it. I picked it up for the QA hangers. Don't have the spindles. Mine is a 3 spindle deck, not sure if a model # is still on it.
#15 jstiteler OFFLINE
jstiteler
  • 9 Thanks
  • 44 posts
Posted September 02, 2012 - 09:55 AM
That would be awesome Kenny. Mine has the 3 spindles also. I will try to get the mesurements off of mine today.
Thank you,
Jason
