Help With Voltage Regulator
john deere kawasaki
5 replies to this topic
#1 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted August 31, 2012 - 02:37 PM
Hello i need Help with voltage regulator its from a john deere 320 i plan to use it on a kohler engine as that this regulator has a no charge light there is 6 terminals i know there 2 for stator 1 for battery 1 for charge light 1 for ground and 1 for power from ignition switch i think the next question is what wire goes where i do have a bit of the wiring harness so i do know where 3 or so wires go also there is a part number
sh578-12
2.2
Any help would be appreciated
cheers
Tyler
#2 JDBrian OFFLINE
  • 9,596 Thanks
Posted August 31, 2012 - 04:54 PM
I don't have any info on those tractors at all. I'll see if I can find another model that uses a similar 6 terminal regulator.
#3 New.Canadian.DB.Owner OFFLINE
  • 2,318 Thanks
  • 1,491 posts
Posted August 31, 2012 - 05:07 PM
This may help.
  • 8tyman8 said thank you
#4 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted August 31, 2012 - 05:35 PM
This may help.
THANKS SO MUCH !!!!!! where did you find that !
#5 HDWildBill OFFLINE
  • 8,971 Thanks
Posted August 31, 2012 - 05:48 PM
This may help.
Attached File  Elect_sys.pdf   159.21KB   130 downloads
#6 New.Canadian.DB.Owner OFFLINE
  • 2,318 Thanks
  • 1,491 posts
Posted August 31, 2012 - 06:58 PM
I Googled: sh578-12 images.
