Stx38 Hood Repair - Plastic "welding"
plastic welding
14 replies to this topic
  • 2,264 Thanks
  • 1,467 posts
Posted August 30, 2012 - 06:42 PM
I saw the posting by Texas Deere and Horse about plastic welding and it got me thinking, "the STX38 needs to have its hood repaired. I wonder ..." The hood is made of Xenoy, at least that is what is stamped inside the hood.
Anyway, I dug out my table saw, an old treadmill, and some Acrylic glue. Once the loose pieces and old patches were removed, I sanded the little ridge of the bottom so the plastic patch would conform nicely. I cut 2" strips of plastic from the treadmill motor cover. The heat gun melted them enough to mold easily. Leather gloves work best for forming. The Acrylic glue bonded the parts quickly but dries fast. I found that wetting both surfaces worked best, kind of like contact cement. Once the patches were installed, I filed the excess off with a hand file.
Lessons learned:
1. Don't wipe the glue runs while they are still wet!
2. Clean the mating surfaces with Acetone, but don't re-wipe over the same area.
3. Leave extra & file smooth.
I like the result, but would be happier if I could get rid of the black streaks & speckles.
  • JDBrian, HDWildBill, larryd and 3 others have said thanks
#2 JDBrian OFFLINE
  • 9,592 Thanks
Posted August 30, 2012 - 07:38 PM
Thanks for posting. I don't think I've ever seen that done before. What is acrylic glue and where do you get it?
#3 New.Canadian.DB.Owner OFFLINE
  • 2,264 Thanks
  • 1,467 posts
Posted August 30, 2012 - 08:37 PM
The label says "Weld-on 3". It is made by IPS, P.O.Box 379, 17109 S Main St. Gardena, CA 90248. It comes in a 1/4 pint tin can with a screw top lids. I got it from a friend who was into building aquariums. It is available on Amazon. As for what is in it, I'd guess nothing you'd want to drink.
http://www.amazon.co...z/dp/B0046CVPN4
  • MH81, Alc and HDWildBill have said thanks
#4 caseguy OFFLINE
Posted August 30, 2012 - 09:20 PM
That looks like a great repair! Thanks for the walk through! Great information too!
#5 Cvans OFFLINE
  • 4,910 Thanks
  • 5,290 posts
Posted August 30, 2012 - 09:58 PM
Your repair came out great. Not being real familiar with John Deere I would not have noticed anything out of the ordinary if you hadn't let us in on the project. I like your oil drain also. :thumbs:
#6 KennyP ONLINE
  • 30,558 Thanks
  • 41,120 posts
Posted August 31, 2012 - 02:20 AM
Looks good. May have to try this on the MTD hood.
#7 mjodrey OFFLINE
  • 2,347 Thanks
Posted August 31, 2012 - 04:52 AM
Looks good,that seems to be a good product.
#8 deere3332 OFFLINE
deere3332
  • 4 posts
Posted September 25, 2012 - 06:45 PM
I bet this would work on the lx and gt hoods
#9 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 12, 2013 - 07:50 PM
Very well done; I have a suggestion if I may and that is where the two bolts come out on each side is if possible to use carriage bolts with the head on the outside, I think it would give it smoother look.
Dick
#10 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 12, 2013 - 07:51 PM
Yea it would work on the LX'S and GT's but think about what usualy breaks on them, around the top at the louvered areas.
Dick
#11 New.Canadian.DB.Owner OFFLINE
  • 2,264 Thanks
  • 1,467 posts
Posted February 12, 2013 - 08:35 PM
I considered carriage bolt, but they interfered with the hinge mechanism.
#12 TAHOE ONLINE
TAHOE
  • 6,740 Thanks
  • 5,101 posts
Posted February 13, 2013 - 10:31 AM
Dick
yea, I repaired a GT242 hood last summer that was broke both at hinges and the louvers. Just picked up a LX178 and the louvers are busted. They are almost as bad as the Sears SS/ST upper grills.
Nice repair!!!
#13 Sawdust ONLINE
Sawdust
  • 4,735 Thanks
  • 2,922 posts
Posted July 21, 2013 - 02:44 PM
Have you tried these. Most box stores won't have them but some older hardware stores would or you could order. Nice job on the repairs looks great.
http://www.boltdepot...ing_screws.aspx
#14 Svxpac OFFLINE
Svxpac
  • 1 posts
Posted December 20, 2013 - 10:30 PM
Our local John Deere dealer tried repairing the cracked hood on my LX178 after the body shop declined the job. It didn't work and I've ordered a new hood. My question is:
"Is there anything that I can do NOW to re enforce my new hood to make it more robust?"
Any and all opinions are welcome!
#15 HDWildBill OFFLINE
  • 8,891 Thanks
  • 8,634 posts
Posted December 21, 2013 - 12:54 PM
If you are talking about a repair, I will usually embed wire screen or cotter pins to help support the repair then melt plastic over the repair.
