Hi,
I just bought a Gravely "5665" the other day. I thought I'd try to confirm the serial numbers to see the year, etc. When I looked I did not find a serial number below the hood at all. I found 2 numbers. One on the engine (Kohler k301S, spec 47459d, SN 6292722), and one on the left lower side (SN- J113001).
The Walk Behind is very clean. Red hood (no number decal), the dash has choke, key, and hi-lo, and PTO engage. No hour meter, or other devices.
From what I can figure out both serial numbers indice 1974. I do not even know the difference between the 500, 5000, and commercial 12 models. Can anyone give me ideas how to check into this? I can take pics of specific areas if that will help.
Thank you
What Model Gravely 2 Wheel Is It?
Started by
herbertk1
, Aug 30, 2012 06:25 PM
5665 566 commercial 12 gravely identify model 5000 500
3 replies to this topic
#1
OFFLINE
Posted August 30, 2012 - 06:25 PM
#2
OFFLINE
Posted August 30, 2012 - 06:47 PM
www.oldgravelys.net
#3
ONLINE
Posted August 30, 2012 - 10:00 PM
I can't help you but someone should be along that can. Good luck.
#4
OFFLINE
Posted August 30, 2012 - 10:32 PM
That should be an 5000 series tractor, as Coldone said go to www.oldgravelys.net lots of information on them
