Drive Belt/s
11 replies to this topic
#1 Dons916 OFFLINE
Dons916
  • 26 posts
Posted August 30, 2012 - 10:02 AM
I just broke another belt.Yes I'm using the one it's called for.Could using just one belt cause this.When I got the tractor it only had one belt.So the open spot I use to run the pump for the hydraulic 3 pt.I just have to go back to two drive belts.How do other run the hydraulic pump
#2 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 4971 Thanks
  • 2859 posts
Posted August 30, 2012 - 11:40 AM
What model tractor ???
#3 Bolens 1000 OFFLINE
  • 17293 Thanks
  • 18793 posts
Posted August 30, 2012 - 12:30 PM
:ditto:
#4 Dons916 OFFLINE
Dons916
  • 26 posts
Posted August 30, 2012 - 01:07 PM
Sorry forgot
FMC G14 model 1453 ser 05.11256
#5 Bolens 1000 OFFLINE
  • 17293 Thanks
  • 18793 posts
Posted August 30, 2012 - 01:13 PM
The G14 should be run with a matched set of 2 drive belts and 2 PTO belts, If the optional Hydraulic pump is installed you should have a total of 5 belts running off the engine's pulley.
Could you possibly post a picture of your tractor and pulley setup so we can tell if its correct for the tractor.
It almost sounds like you have the wrong pulley from a 3 speed tractor on there now.
#6 Dons916 OFFLINE
Dons916
  • 26 posts
Posted August 30, 2012 - 03:49 PM
SANY0001.JPG SANY0003.JPG SANY0005.JPG SANY0006.JPG SANY0006.JPG SANY0007.JPG SANY0008.JPG SANY0009.JPG SANY0010.JPG SANY0011.JPG
#7 mark843 OFFLINE
mark843
  • 18 Thanks
  • 202 posts
Posted August 30, 2012 - 04:01 PM
It looks like you have the setup wrong. Run the 2 matched belts on the 2 back groves of the pulley on the rear of the engine. Both the PTO belts and belts to the drive shaft should have 2 belts. See the pic below where you add the hydraulic pump belt.
Can you take a picture of the right side of the tractor? It looks like the hydraulic pump is not mounted correctly either (too far back?) so you will not be able to match the grove in the pulley on the pump to the correct grove on the engine pulley.
  • Bolens 1000 said thank you
#8 Dons916 OFFLINE
Dons916
  • 26 posts
Posted August 30, 2012 - 04:08 PM
I'm new to posting pic,But I think this will show what you are looking for.Engine only has two groves.This can be replaced with three??
#9 Bolens 1000 OFFLINE
  • 17293 Thanks
  • 18793 posts
Posted August 30, 2012 - 04:16 PM
:ditto:
Mark is 100% correct.
Your hydraulic lift appears to be homemade.... The pump should be facing the other way and should be next to the engine if it is factory.
#10 Dons916 OFFLINE
Dons916
  • 26 posts
Posted August 30, 2012 - 04:35 PM
Thanks the third grove I never would have never saw it..Problem salved.Big repair job though.Will have to move the pump and get new hydraulic lines ( longer)But it will be well worth it
Yes it is home made The pump is off a Ford Mustang,The control valve is off a Wheel horse.It has a 6" ram and the lift arm are off a 9N cut down 4".Works great.Just wish it was a little faster lifting faster.
THANKS AGAIN FOR THE HELP. Don in California
#11 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted August 30, 2012 - 05:45 PM
Going from the pulley you have it on to the front one will slow things down more. (size Diffs)
  • Dons916 said thank you
#12 8tyman8 OFFLINE
8tyman8
  • 437 Thanks
  • 743 posts
Posted August 31, 2012 - 12:28 PM
what you need is some kevlar belts and you need to move your pump to the small pulley in-between the bigger pairs of groves and put a smaller pulley on the pump also the belts are A32 for drive and A41 for pto i got good year insta-power belts for my h14 after breaking MANY sets of Jason belts and other brands and they where kevlar the repower engine was to much torque for the belts
