Chance To Buy A Ford 1100 W/ Implements--opinions?
ford 1100 diesel sabaura
2 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted August 27, 2012 - 10:29 PM
I have a chance to buy a Ford 1100... it has the tractor, along with a snowblower, rear blade, mower, and tiller. Price seems to be reasonable at $3,000 though the owner isn't sure how many hours on it, etc.
Any opinions on these tractors??? It's an ideal size for what I want to do, and has a 0.7 liter 2 cylinder diesel in it and mechanical 4WD.
Are parts hard to find... I suspect they're expensive... are they reliable?
TIA
Utah Smitty
#2 mjodrey OFFLINE
  • 2,355 Thanks
Posted August 28, 2012 - 04:50 AM
I used to use one of those a few years ago,where I used to work.They're a good tractor.If I remember correctly,it was very reliable.I don't think we ever had to do much of anything to it. I can't remember right off what make of engine it was.
  • Utah Smitty said thank you
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 28, 2012 - 07:51 AM
Been reading up on the compacts and consIder the Fords to be a good choice.
They were bAOught out by New Holland so parts should not be a problem.
Dont let the size fool you. While it is a little guy, it will be about 500 lbs heavier than a GT.
ithe the 3point and traction lock the little guy will do a lot of work.
In case your wondering Im looking for a compact for my 9 acres.
Let me correct myself. Ivthink that would be closer to 200 lbs heavier than a GT and wit the attachments would be a very good price. Look it over good to check condition.
pHour meters often don't work on these old machines, so I don't consider them a reliable indication of condition.
The implements in that package is iexactly what I'm looking for.
As I recall that is built by SHibara
Please overlook the spelling errors,im trying to get used to the ipad and not used to the keypad yet.
Edited by JD DANNELS, August 28, 2012 - 11:28 AM.
