Body Mounts For Lgt145
15 replies to this topic
#1 CASENUT OFFLINE
  • 505 Thanks
Posted August 27, 2012 - 09:20 PM
I should be putting the body on the frame this weekend, anyone know where I can get a body mount kit...consisting of all the rubber mounts with the screws in them? or anyone have a good alternative? Some of mine busted and I'd like to replace em all if feasible...I could always 'fab' something together but if the 'right' ones are available...
#2 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted August 28, 2012 - 03:19 AM
McMaster Carr has the exact ones you need . :)
  • CASENUT said thank you
#3 KennyP ONLINE
  • 40,012 Thanks
  • 46,722 posts
Posted August 28, 2012 - 03:37 AM
That's where I got mine.
#4 poncho62 ONLINE
poncho62
  • 1,979 Thanks
  • 1,735 posts
Posted August 28, 2012 - 04:55 AM
I just cut some washers out of some 3/4" rubber belting I have with a hole saw...Put a bolt through it...works just as well
  • IamSherwood said thank you
#5 CASENUT OFFLINE
  • 505 Thanks
Posted August 28, 2012 - 07:06 AM
part # by chance? hmmmm wonder if fastenal may have em or graingers? I have those locally... i'll look there too
#6 KennyP ONLINE
  • 40,012 Thanks
  • 46,722 posts
Posted August 28, 2012 - 07:18 AM
I don't remember the exact ones I got. Not sure where the receipt is. But here's a link to them:
http://www.mcmaster....-mounts/=j1lxpk
I think it was the 9213K31
#7 CASENUT OFFLINE
  • 505 Thanks
Posted August 28, 2012 - 08:02 AM
Thx...I see fastenal and graingers has them listed too...I'll report back w/findings
  • Utah Smitty said thank you
#8 Utah Smitty ONLINE
Utah Smitty
  • 1,705 Thanks
  • 1,789 posts
Posted September 01, 2012 - 01:53 AM
What did you use for the rubber "isolator" between the frame and engine mount? One of mine is completely gone and another is badly deterioted.
Also the rubber flex coupling that goes on the drive shaft between the engine and hydro...
Regards,
#9 KennyP ONLINE
  • 40,012 Thanks
  • 46,722 posts
Posted September 01, 2012 - 02:57 AM
Regards,
These:
http://www.mcmaster....-mounts/=j3kowm
#10 CASENUT OFFLINE
  • 505 Thanks
Posted September 01, 2012 - 09:09 AM
Regards,
Steve, My motor is welded in, so there are no mounts...the drive shaft rubbers were in great shape maybe I just lucked out on that one But I'd bet you could fab one out of an old tire...GL
#11 Utah Smitty ONLINE
Utah Smitty
  • 1,705 Thanks
  • 1,789 posts
Posted September 01, 2012 - 03:46 PM
These:
Kenny
Do you know the specific one you bought? I've found one possible mount... it's in a square metal holder--dimensions are similar thought I don't know if there is a steel sleeve in it.
#12 KennyP ONLINE
  • 40,012 Thanks
  • 46,722 posts
Posted September 01, 2012 - 03:56 PM
I think it was the 6008K33. That has 45 lbs per mount. Engine weights in at less then 150. I have tried to find these #'s, but I don't remember where we talked about them.
#13 CASENUT OFFLINE
  • 505 Thanks
Posted July 16, 2014 - 10:25 PM
Resurrecting an old thread. Time to finish the Ford, still stuck on the body mounts. An old friend gave me the number and now I cannot find it anywhere. I am going to finish this tractor. They are a flat topped bolt glued to a rubber isolator, on both sides of the configuration. Someone has them grainger or carr or someone I forgot. But I want to get this tractor done. Anyone?
...Ha found it...now...what size...http://www.mcmaster....-mounts/=svbwco
Edited by CASENUT, July 16, 2014 - 10:27 PM.
#14 Rock farmer ONLINE
Rock farmer
  • 1,215 Thanks
  • 1,242 posts
Posted July 17, 2014 - 05:30 AM
The ones at the foot rests are smaller than the ones at the upper seat pan.
You'll have to drill them out and cut off the excess thread.
You can also super glue the old ones back together if they just came apart!
Joe
#15 TomLGT195 OFFLINE
TomLGT195
  • 4,010 Thanks
  • 2,881 posts
Posted July 17, 2014 - 05:32 PM
here's were i got mine ,http://www.ebay.com/...atchlink:top:en, I didn't look that close at it the link to see if that's the right size , I had the wrong size saved before,
he carries all sizes. good luck
