Gt14 Auto Trans Manual?
6 replies to this topic
#1 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted August 27, 2012 - 06:15 PM
I see some manuals for standard trannies in listing, nothing on automatic/hydros. Would like to find one for my GT14. Does the gear case part look pretty much like the stick trans and maybe one of those is close for that part? Then would need Sunstrand manual for rest?
#2 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted August 27, 2012 - 08:41 PM
Never seen a GT14 up close but Ihave the manual for the sundstrand +rearend for the C and D series if you want it.
#3 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted August 27, 2012 - 08:49 PM
Think may be same or similar to D series. There are tag numbers on it, that help? Seems a little diff in #'s than my Charger one in shed. Yeah, I'ld like to take a look. How do we do that? This book for sale, something to download, or what? Can you post here? Or glperry4 at yahoo dot com for email.
#4 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted August 28, 2012 - 05:27 AM
I will get it to you tonight grumpy
#5 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted August 31, 2012 - 09:31 PM
Cold one, got an email from a Britt C., so if that is you, thanks! Got them all printed out now. Haven't had time to really look close thru it, but will when I can. I power-washed the tractor today and cleaned up good. Have it torn all apart down to the frame axles and wheels. Was looking at the cast pulley on the rear pump and it was loose. Not just loose, but the keyway in the pulley is way wallowed out. Key was about half size too. Crank looks good. Guess I'll be looking for a pulley then. Has numbers on it, but didn't bring it in with me to post. Still can't find a push lever. I see in two places in book, but mine has none. SO, can I just take one out of another axle and it will work, or is it not going to be set-up inside for it?
#6 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted August 31, 2012 - 11:16 PM
Yep that was me, BrittC. I have no idea about the GT14. Is yours the Hydrogear Unit?
#7 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted September 01, 2012 - 10:48 AM
Yep, says model 90-2062 hydro gear on tab. Also has ?2-KA 45303 for serial. First letter can't read. Haven't seen referance to those numbers anywhere. The model is what the model list shows for GT14 of 69 year.
