What Are These Wheels From?
9 replies to this topic
#1 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted August 24, 2012 - 08:37 PM
Got a couple wheels for $1 each. Just thought were neat and heavy, so got them. Not sure what I will do with them, just have them, heh! Any clues why they lock or ratchet or whatever on back side? One tire was good, other torn up. 12" rims so other tires will fit.
#2 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted August 24, 2012 - 08:45 PM
Verry interesting. Looks like the PO painted them with a garden hose. Never seen any like them before.
#3 bowtiebutler956 OFFLINE
bowtiebutler956
  • 669 Thanks
  • 796 posts
Posted August 24, 2012 - 11:01 PM
Wow, those are very unique looking. Sorry, but I don't have a clue what they were for, but I'm sure you'll find a use for them. I know I would. :thumbs:
Matt
#4 [email protected] OFFLINE
[email protected]
  • 1302 Thanks
  • 1416 posts
Posted August 24, 2012 - 11:55 PM
I'm thinking some type of a warehouse/airport cart, and the cam was for locking/brake it in place maybe?
#5 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted August 25, 2012 - 04:36 AM
I don't think they are off any GT I have ever seen,so I'm not sure.
#6 Oo-v-oO ONLINE
Oo-v-oO
  • 344 Thanks
  • 448 posts
Posted August 25, 2012 - 06:01 AM
My guess would be off of a walk-behind 2-wheel tractor.
The ratchet mechanism is probably what they used in place of a differential. Looks like the axles extended through the hub and only the ratchet was driven, with the hub freewheeling on the axle otherwise. Might even be set up so the ratchet dogs would flip outward and stay there to give it a neutral.
Just guessing, though.
  • 15135 Thanks
  • 15577 posts
Posted August 25, 2012 - 03:55 PM
I wonder if they might be off a mechanical lift from a pull type plow or something like that. I don't remember what the lift looks like or I would be more sure.
#8 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 18862 Thanks
  • 11842 posts
Posted August 25, 2012 - 07:38 PM
More important, what are you going to use it for? They might look nice on the front of a tractor. you could even make some rears to match.
#9 KC9KAS OFFLINE
KC9KAS
  • 5535 Thanks
  • 4770 posts
Posted August 25, 2012 - 09:07 PM
This was my thought too.....for turning your walk-behind tractor.
#10 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted August 26, 2012 - 11:10 AM
The differential idea is what show guy told me. He says to turn a two wheel tractor, the ratchet allows the outer wheel to kinda free-wheel faster than inner doing all the work. And it is same for reverse, thus two ratchets. I did see some at show with similar wheels on them, not as heavy, so guess that looks about right. Tires seemed about the same as those too. Wish that one wasn't torn up, I would leave those on. Wonder if I could ever find a match for the good one? Otherwise will be putting 3 ribs on them and use on a front axle or trailer maybe. No real plan as of yet.
