How To Repair Cast Pulley
cast pulley massey
10 replies to this topic
#1 ShelbyGT550 OFFLINE
ShelbyGT550
  • 16 posts
Posted August 24, 2012 - 07:37 PM
This is off my Massey 12, The cast broke when trying to remove it the stupid way (Hammer) ended up buying a real puller so no more of this happening, But how can I put these parts back on?
I still have the parts and they fit perfect in the spots they came from< but how do I keep em there?
#2 Kurtee OFFLINE
Kurtee
  • 592 Thanks
  • 471 posts
Posted August 24, 2012 - 07:42 PM
I am inclined to say that a replacement is in order. Welded will eat belts and throw the balance off. Chalk it up to education and move on.
KURTEE
#3 olcowhand ONLINE
  • 42,348 Thanks
  • 31,787 posts
Posted August 24, 2012 - 07:46 PM
The pieces could be welded back on with nickel rod, but I recommend either replacing the pulley, or just rounding the inside edge of the breaks & using as is. There won't be enough difference to cause any noticeable balance issue, and if rounded, no harm will be done to the belt. I've run chipped out pulleys for years with no problems whatsoever.
  • powerking56 said thank you
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,360 Thanks
  • 5,605 posts
Posted August 24, 2012 - 08:13 PM
Is that pulley off of a gear drive, Vari-drive?
#5 ShelbyGT550 OFFLINE
ShelbyGT550
  • 16 posts
Posted August 24, 2012 - 08:25 PM
^ Yes it is, I have a hard time finding a replacement (need two, one for the 10 and now this one) And I am beyond tight on cash. Hence why i was hoping it could be fixed
#6 DH1 ONLINE
DH1
    Electric Tractors
  • 5,360 Thanks
  • 5,605 posts
Posted August 24, 2012 - 08:28 PM
I think I can get you 1 or 2.
You live near Mitchel Ont?
#7 ShelbyGT550 OFFLINE
ShelbyGT550
  • 16 posts
Posted August 24, 2012 - 09:01 PM
I live near Sault.Ste.Marie Ontario,
#8 Utah Smitty ONLINE
Utah Smitty
  • 1,706 Thanks
  • 1,791 posts
Posted August 24, 2012 - 09:22 PM
I agree with Daniel--just round the rough edges slightly to avoid chewing up your belt and run with it... There isn't a large area broken out so you won't have a problem.
#9 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 24, 2012 - 09:49 PM
File, grind them, and you should be O.K. Only replace if it eats belts. Proper tool for the proper job. Did I just say that? I need to listen to my own advice.
#10 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,103 Thanks
  • 1,897 posts
Posted August 24, 2012 - 11:04 PM
For what it's worth ...
I've repaired cast pulleys with a broken area like that before.
Grind the edges of the broken out area and the mating pieces so there is "V" area on boths sides at the break line.
Clamp the pulley and the broken out pieces to a flat piece of metal and braze them together.
Then turn the pulley over and braze the other side ( do this carefully so you don't melt out the braze that you had just put in ).
Put the pulley in a lathe and turn the brazed area down until it is flush with the surface.
This repair works fine on a pulley that just has a small area like that broken out.
If the broken area is larger, than it really needs to be tig welded and that gets much more envolved.
Edited by jdcrawler, August 24, 2012 - 11:06 PM.
#11 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted August 24, 2012 - 11:06 PM
Been there, done that! :mad2: Its very frustrating, but I agree with the others, take off the sharp edges, and you won't have a problem. The drive pulley on my Wheel Horse is missing a larger piece than that, and I've never had a problem. :thumbs:
Matt
Also tagged with one or more of these keywords: cast, pulley, massey
