Where do you purchase Replacement Reverse Discs For The Walkbehinds/ride-a-matics?
6 replies to this topic
#1 Bolens 1000 ONLINE
  • 17303 Thanks
  • 18797 posts
Posted August 24, 2012 - 03:40 PM
A while back I remember reading somewhere that someone was making reproduction fiber reverse discs for the Walk behinds and Ride-a-matics but don't remember where I saw it.
Does anyone have a source/ contact info for these?
Part number 1706373
I cant get my HD versa-matic to go in reverse since the old disc is so worn.......
#2 wilberj OFFLINE
wilberj
  • 5547 Thanks
  • 5736 posts
Posted August 24, 2012 - 04:04 PM
I belive bob has some.
  • Bolens 1000 said thank you
#3 plumberroy OFFLINE
plumberroy
  • 12 Thanks
  • 18 posts
Posted August 24, 2012 - 06:28 PM
The one on the super versi matic I used to have was brass I ended up having a machinest I worked with at the time make it cost me a turkey baecon ranch market fresh samwich. There Are times I miss working in a factory :mecry:
Roy
  • MailmAn said thank you
#4 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 4972 Thanks
  • 2860 posts
Posted August 25, 2012 - 12:05 AM
The correct part number for the large-diameter fiber reverse disc is 1706376, not 373.
There were different reverse discs for the VersaMatics.
Part #1703532 was used on 15FC-01 and 15FD-01 tractors.
Part #1704965 was used on 15FC-02, 15FD-02, 153-03 and 154-03 tractors. (Also used on 1956-57 Ride-A-Matic models 20HD.)
Both of the above drive discs were mounted on the engine pulley. ......One disc was made of bronze, the other disc was fiber (composite), but I can't remember which was which. (I think the fiber was the later style, replacing the bronze discs, but I am not certain.)
Part # 1706376 was used on 15FH-01 and 155-02. (Also used on the following RideAMatics: 1957 model 21HD, 1958 model 220, 1959 model 230, and 1960 models 231 & 232.)
Part # 1706376 was a fiber (composite) disc, and was mounted on the driven (variable speed) pulley.
  • Bolens 1000 and MailmAn have said thanks
#5 Bolens 1000 ONLINE
  • 17303 Thanks
  • 18797 posts
Posted August 25, 2012 - 07:03 AM
Oops! That was me, I typed in the wrong number at the end :wallbanging:
The Bronze was the early disc as my 55' Versa-Matic has the hard to find bronze disc. Luckily I have 2 NOS ones stashed away :D
#6 plumberroy OFFLINE
plumberroy
  • 12 Thanks
  • 18 posts
Posted August 26, 2012 - 06:04 PM
The one I had made was bronze mine was cracked
#7 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted August 26, 2012 - 09:03 PM
Brian if you need the disc i have all of them bronze and fiber in stock.
