169 Cub Questions..
35 replies to this topic
#16 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted August 24, 2012 - 03:36 PM
The motor is out of a QuietLine Cub.
#17 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted August 24, 2012 - 03:44 PM
Like a 1650?
#18 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted August 24, 2012 - 04:41 PM
Looks like it to me, it has part of he muffler box.
#19 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted August 24, 2012 - 05:16 PM
That is definitely a quietline engine. Its black,has different sheet metal,a gear starter,muffler box,coil mounted different. Still a cool Cub though. Always wanted a 169.
Edited by LTD, August 24, 2012 - 05:18 PM.
#20 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted August 24, 2012 - 05:24 PM
With that S.N. It looks to have been built in October of '74.
#21 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted August 24, 2012 - 06:13 PM
That would be one of the last ones made.
#22 Cvans ONLINE
  • 7,480 Thanks
  • 6,473 posts
Posted August 24, 2012 - 07:56 PM
If it was one of the last built it could be a Frankenstein tractor built during the transition.
#23 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted August 25, 2012 - 11:50 AM
They were running out of parts for assembly during the production run of the 169. I just think looking at the wiring that is there, that this is a replacement engine and the wiring was butchered in the engine swap.
#24 KennyP ONLINE
  • 41,503 Thanks
  • 47,416 posts
Posted August 25, 2012 - 12:32 PM
You're probably right, Brian. Sometimes I wish my 108 had an electric PTO.
#25 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted August 25, 2012 - 12:33 PM
It should of had the PTO with he brake on it, I believe they started installing those in Sep 73.
#26 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted August 25, 2012 - 12:34 PM
The manual is much better, you can ease it in and it's a lot cheaper to rebuild.
#27 KennyP ONLINE
  • 41,503 Thanks
  • 47,416 posts
Posted August 25, 2012 - 12:40 PM
I've had that sucker off 4 times adjusting it and it still burns the buttons up within a days usage.
#28 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted August 25, 2012 - 01:21 PM
Do you have any space between the button and clutch? I keep about 1/16" between mine, and when I don't have my on it that uses a belt I readjust it where the clutch is engaged all th time and the button isn't touching. I also use a brass button in the arm.
#29 KennyP ONLINE
  • 41,503 Thanks
  • 47,416 posts
Posted August 25, 2012 - 03:52 PM
Yes there is a gap, it's when I want to shut the mower off that it eats the buttons.
#30 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted August 25, 2012 - 03:57 PM
Do you have the button in the arm?
Edited by Amigatec, August 25, 2012 - 03:58 PM.
