Restoration Tip
23 replies to this topic
#1 CASENUT OFFLINE
  • 502 Thanks
Posted August 22, 2012 - 08:10 PM
When you are taking apart an old tractor to restore and put all the fasteners in a small container what do you do when you are waiting on reassembly? If you let them sit they will gather more corrosion...Yet if you mix a quart of 1/2 Acetone and 1/2 Transmission fluid and mix it up (this is also a very good homemade penetrating oil)...if you soak the fasteners the rust, dirt, crud and old paint will just fall off. So when you go to reassemble the fasteners will go on (and in most cases look) like new. Sometimes you may have to wire brush some of the crud off but for the most part the hard stuff is done for you.
Stumbled on this 'tip' when I was restoring the LGT145 and wanted to share it with everyone, yep it makes a big difference.
You may want to 'shake' or stir em from time to time...just to loosen and drop deposits in the bottom...
Good Luck and if anyone else trys this post up...
Edited by NutCASE, August 23, 2012 - 12:39 AM.
  • mjodrey, kwj427, daytime dave and 13 others have said thanks
#2 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted August 22, 2012 - 08:15 PM
I have done that with kerosene, but the acetone & ATF would have lots more detergents & solvent power.
I'll have to try that if I ever get the time to take a tractor apart...
  • CASENUT said thank you
#3 Newpaws493 OFFLINE
Newpaws493
  • 1,152 Thanks
  • 1,692 posts
Posted August 22, 2012 - 08:17 PM
Any issues if they stay soaking., lets say weeks?
#4 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted August 22, 2012 - 09:19 PM
Thanks for the tip! :thumbs:
Matt
#5 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 553 Thanks
  • 1,781 posts
Posted August 22, 2012 - 09:24 PM
I use equal parts transmission fluid, Brake fluid and Marvel Mystery oil
  • CASENUT, johndeereelfman and LilysDad have said thanks
#6 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted August 22, 2012 - 10:16 PM
I have little 8 ounce containers I keep my bolts in. First i put them in the walnut tumbler, then give them a kroil bath. After that I I put a paper towel on the bottom of the container, drop the bolts in, and put another paper towel on top. The paper towels hold the excess kroil, and keep the bolts from rusting, That's just what I do though. Thanks for the tip, that would probably be cheaper than Kroil!!! :dancingbanana: :dancingbanana: :dancingbanana:
#7 Clippnalawn OFFLINE
Clippnalawn
  • 110 Thanks
  • 104 posts
Posted August 22, 2012 - 10:58 PM
I have used the 50/50 ATF and acetone for a penetrating oil before and i think it really is better than anything off the store shelf! I will have to try the bolt bath, thanks for the tip!
#8 CASENUT OFFLINE
  • 502 Thanks
Posted August 23, 2012 - 12:35 AM
No, but make sure there are no composite nor rubber parts, just springs, steel, metal etc...when you put them back together ...well you will see it when you take the parts out...
#9 JDBrian OFFLINE
  • 9,593 Thanks
Posted August 23, 2012 - 05:07 AM
Thanks for the tip. If the container is open does the acetone evaporate from the solution pretty quickly? I'm wondering if it would soften plascic containers as well.
#10 CASENUT OFFLINE
  • 502 Thanks
Posted August 23, 2012 - 09:14 AM
Didn't seem to harm mine, I used an old plastic mcdonalds salad tray...
  • JDBrian said thank you
#11 Wheel Horse Kid OFFLINE
Wheel Horse Kid
    Certified Wheel Horse Nut
  • 213 Thanks
  • 817 posts
Posted August 23, 2012 - 09:35 AM
Good tip there! Thanks for sharing with us!
#12 JDBrian OFFLINE
  • 9,593 Thanks
Posted August 23, 2012 - 10:16 AM
Thanks for the tip. Anything to save work in a restoration is worth trying IMO especially in a saved tractor where wevery bolt pretty much needs attention.
#13 bh115577 ONLINE
bh115577
  • 442 Thanks
  • 240 posts
Posted August 23, 2012 - 11:33 AM
Here is some info I read a few years ago. Been using the home brew ever since.
Penetrating oil comparison
Interesting stuff to my friends that turn a wrench!
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results! They are below, as forwarded by an ex-student and professional machinist, Bud Baker.
*Don't forget the April 2007 "Machinist's Workshop" magazine comparison test.*
*They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment. *
Penetrating oil ..... Average load*
None ............ ......... 516 pounds
WD-40 ............ ...... 238 pounds
PB Blaster ............ . 214 pounds
Liquid Wrench ..... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
*The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
transmission fluid and acetone.*
*Note the "home brew" was better than any commercial product in this one
particular test. Our local machinist group mixed up a batch and we all
now use it with equally good results. Note also that "Liquid Wrench" is
about as good as "Kroil" for about 20% of the price. *
*Your experience may vary, etc., etc.
  • John@Reliable, limebuzz and Ryan313 have said thanks
#14 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
That is a great tip! Thanks Jim! I will be sure to try this one!
#15 John@Reliable OFFLINE
John@Reliable
  • 1,296 Thanks
  • 1,416 posts
Posted August 23, 2012 - 12:44 PM
Very interesting results
