60 Inch Mowin Deck
17 replies to this topic
#16 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 23, 2012 - 08:09 PM
Yea it works but it flops alot also,, I just got a 115 inch today an it works alot better then the 116 did,, It pop off a couple time with the 116 inch but thats what was with my 195 when I got it,, But now its much better an I will see how long this belt lastes,, Got it from NAPA an its 5/8 wide an thick,, Belt # is B112 from NAPA
#17 Newby13 OFFLINE
Newby13
  • 2 Thanks
  • 12 posts
Posted May 12, 2016 - 02:52 PM
How do you remove your deck is it a drive over or do you have to manually pull it out.
#18 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted May 12, 2016 - 05:04 PM
On mine, I jack up the front of the tractor and slide it out from the side. Easy to do as the deck wheels are like casters. First unhook the "U" shaped front mount and remove. Next disconnect the front deck lift. Then raise the front of the tractor up. Unhook the rear deck lift.  Slide out the side. Fairly easy and no need to lift the heavy deck.
Edited by Bmerf, May 12, 2016 - 05:09 PM.
