60 Inch Mowin Deck
17 replies to this topic
#1 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 22, 2012 - 03:41 PM
I am a lil puzz about trying to get a belt for my 60" mowing deck,, I messured it an got 116" inches long,, The Serial # on my deck is 09JC9868 1648 ,, Had my wife call new holling an they said the belt cost 73 something an says the Serial # calls for a 113" inch belt,, So I just trying to fig out for sure if anybody knows for sure what size belt is pos to go on the 60" inch decks,, The deck is with my Ford 195 ,, Also my wife called NAPA an can get the belts for 20 bucks, Wow what a diff in the price,,
#2 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted August 22, 2012 - 03:48 PM
Does the mower deck have an idle pulley on a spring tensioner? If it does, did you pull it back some when you measured? If not, they can throw your measurement off quite a bit.
  • Russ said thank you
#3 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 22, 2012 - 04:16 PM
The old belt broke off with a smooth cut so its easy to see how long it is,,A I didn't messure the deck like you talking about Ryan313 An yes it has the idle pully with the spring,
#4 KennyP ONLINE
  • 40,858 Thanks
  • 47,081 posts
Posted August 22, 2012 - 04:18 PM
I'd be checking it for length. I couldn't get that from NH online. If the one from NAPA is the right length, I'd buy it.
#5 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 22, 2012 - 04:42 PM
Yea NAPA has the right one an had to order it so I will have it Friday morning,, The belt was pretty old from setting around a couple years up north an I glad it lasted this long,,lol,,
#6 olcowhand OFFLINE
  • 42,895 Thanks
  • 31,937 posts
Posted August 22, 2012 - 04:50 PM
Ford part #634069 V-BELT 0.66" W x 114.90" L, Cutter Blade Drive
$68.76
3-5 days
Here is the link to the page at Messick's: 60" Deck Parts Messick's
#7 poncho62 OFFLINE
poncho62
  • 2,106 Thanks
  • 1,779 posts
Posted August 22, 2012 - 05:45 PM
Dont know about the length, but the NAPA I work at has 2 lines of belts....There is the cheaper and more expensive line...The quality goes along with the price.....I put one of the cheaper ones on my STX38 and it only lasted a couple of months...the better one is lasting mucch longer so far......just saying
  • Alc and Russ have said thanks
#8 olcowhand OFFLINE
  • 42,895 Thanks
  • 31,937 posts
Posted August 22, 2012 - 05:51 PM
A std 5/8" belt measures .625" and the OE belt measures .660". Also sometimes tractor companies make their belts a different fron std angle so you need to get the belts from them, as std angles will wear out on some pulleys. Not sure in this case.
#9 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 22, 2012 - 10:41 PM
Russ can I get a picture of this spring/pulley assembly? My spring is gone, not exactly sure what it is suppost to look like. I just adjusted my new belt until I felt is was "right." I will measure my belt tomorrow to get you a length, thanks.
#10 KennyP ONLINE
  • 40,858 Thanks
  • 47,081 posts
Posted August 22, 2012 - 11:01 PM
Russ, are you wanting the mower blade belt or the belt from the PTO to mower? The # Daniel gave is for the blades (#32) on the deck, but your pic shows it on there. The PTO-to-mower belt is # 251396 (#22). I can't find it in the NAPA cross.
#11 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 23, 2012 - 06:55 AM
I will get a pic for ya Bmerf,,, An Kenny, I am talkin about the belt for the deck itself for the blades,, This pic is an older pic before the belt broke,,
  • Bmerf said thank you
#12 KennyP ONLINE
  • 40,858 Thanks
  • 47,081 posts
Posted August 23, 2012 - 07:08 AM
Okay, then Daniels info is what you need. I thought it was the drive belt. If you can, take it along and have them measure it so we have that info on file here.
#13 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 23, 2012 - 07:17 AM
Ok will do Kenny
#14 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 23, 2012 - 07:22 AM
A better Pic of my mowin deck with patch up belt,, :smilewink:
#15 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 23, 2012 - 06:50 PM
The new belt that I purchased is 116 inches. It fit perfectly.
