Safety Switches?
4 replies to this topic
#1 SammyRye OFFLINE
SammyRye
  • 41 Thanks
  • 45 posts
Posted August 20, 2012 - 04:33 PM
Seems as tho there's been a lot of discussion lately about the 990's being hard to start and having to fiddle with the ignition system, and on and on.
On both of my 990's, there are 2 safety switches - one on the brake and one on the mid-PTO. Do these switches also contain a resistor? I know a lot of guys just bypass the switches (done it myself), and the system seems to work - but, if there's a resistor in there, may that also contribute to hard / no-start issues?
Thanks for your input,
Rich
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 20, 2012 - 05:18 PM
They don't contain a resistor . It's just a switch. However when they get old they can develop enough resistance due to corrosion and wear to cause problems with the starting circuit. The extra resistance causes a voltage drop and at some point there isn't enough current flowing to bring in the solenoid. This can also be a problem in old ignition switches. I recently repaired both the ignition switch and the safety switches for my MF8. Heres links to some pictures of both repairs if you're interested.
http://gardentractor...tch#entry153458
http://gardentractor...tch#entry152862
  • SammyRye said thank you
#3 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted August 20, 2012 - 06:50 PM
I had a similar problem with the safety switches on my John Deere STX38. There is a mod you can do that inserts a relay before the solenoid. The lower voltage left after the dirty safety switches is enough to hold the relay closed. The relay dumps battery voltage directly onto the solenoid. I posted a diagram in the John Deere forum:
http://gardentractor...138-wont-start/
#4 SammyRye OFFLINE
SammyRye
  • 41 Thanks
  • 45 posts
Posted August 20, 2012 - 06:54 PM
Thanks, Brian :thumbs:
That's what I was thinking - just a switch. Ok, so then I can disconnect without causing a problem.
Thanks again,
Rich
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 20, 2012 - 07:10 PM
Rich, You would need to connect the wires together that normally connect to the switch to simulate the switch being closed.
Thanks again,
Rich
The problem is that you no longer have the safety function provided by the switch!
