Any Fix For Plastic Tanks?
10 replies to this topic
#1 glgrumpy OFFLINE
  • 8,618 Thanks
  • 7,926 posts
Posted August 19, 2012 - 11:44 PM
Have a Power King with big plastic tank. Noticed a bad spot in it today that looks like a hard edge scraped along tank and deposited the rubbed out plastic at one end of the scrape. At first thoght it was cracked, but doesn't appear to be thru the plastic. Anyone have special trick or compound one could put on this area to strengthen? Fiberglass? I have some JB Weld like stuff that says it resists gas and fuels? Seems I've heard from snowmobilers that there isn't much you can do with those tanks. Anyone?
  • 14,814 Thanks
  • 15,502 posts
Posted August 19, 2012 - 11:53 PM
JB Weld makes a Plastic weld epoxy that will work on your tank.
#3 CASENUT OFFLINE
  • 505 Thanks
Posted August 20, 2012 - 12:12 AM
I think POR15 also has a tank repair kit that works on PVC tanks...
#4 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted August 20, 2012 - 12:17 AM
To add to NutCASE' post..
http://www.por15.com...oductinfo/CTRK/
#5 mjodrey OFFLINE
  • 2,356 Thanks
Posted August 20, 2012 - 06:04 AM
They can be plastic welded.
  • UncleWillie said thank you
#6 glgrumpy OFFLINE
  • 8,618 Thanks
  • 7,926 posts
Posted August 20, 2012 - 11:27 PM
Repair's off. Foud with flipping my rear-end and the bulk of the case is on top now, the tank won't set down in tractor anymore. It had big indent for the rear. Can't move forward enough then to get axles to line up with their indents either. SO, will be looking for smaller probly metal tank to mount on same cross member which goes hight to mount seat/tail too. I'm at Portland this week, will have to look around and see what I can find. Was setting up some today and lots of GT parts were moving in. Going back for more tommorrow, but rules say NO BUyING till Wednesday when show actually opens!! Can look around if set-up, just can't buy, or not supposed to anyway. They can throw you out if you do. Have heard of that happening to couple vendors in past.
#7 HDWildBill OFFLINE
  • 8,975 Thanks
Posted August 21, 2012 - 09:30 AM
I've used the plastic weld on an old tank. It does well on a straight smooth surface but at a seam it didn't do so well.
#8 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted August 25, 2012 - 06:51 PM
The only method that I have tried, is the heat up the plastic a little and try forming and melting the two pieces back together if possible. I have a windshield washer tank in my old truck that cracked and leaked, and all I did was melt it together again. Never leaked again after that.
#9 Texas Deere and Horse ONLINE
  • 14,814 Thanks
  • 15,502 posts
Posted August 26, 2012 - 04:06 PM
I found our old thread on Plastic welding if anyone is interested.
http://gardentractor...lastic-welding/
  • HDWildBill said thank you
#10 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 09, 2012 - 04:05 PM
When you are trying to weld two pieces together the main object is to get both pieces liquidfied so they melt together, other than that it is a waste of time. Just like welding metal you need to two pieces liquidfied to have any luck.
Dick
#11 Tankman OFFLINE
Tankman
  • 298 Thanks
  • 299 posts
Posted January 23, 2013 - 04:32 PM
I've used a soldering gun, welding plastic many times. I've also used a soldering iron
welding heavy plastic; i.e.: 1/2" thick.
Filler rod (plastic) is available but, I usually just use a piece (strip) of plastic that
I cut from a milk or juice bottle.
Slow with the soldering gun. :wave:
