Sleeve To Cat 0 3pt Adapter
9 replies to this topic
#1 olcowhand ONLINE
  • 38,038 Thanks
  • 30,448 posts
Posted August 19, 2012 - 12:58 PM
Trying to get some things ready for my plow day, and I have 4 sleeve hitch Brinly 10" plows. I have one welded to a tool bar rigid, but have 3 more plow & need sleeve to cat 0 adapters. I still have an old one I made years ago, and it works fine, but is adjustable only in 2" increments to align the implement, as the pic shows.
Yesterday after morning milking, before lunch, I got this new "sliding" adapter 90% finished, and completed it this morning, other than painting it. You simply loosen the 2 lock bolts on the rear of the slider, position, then tighten the lock bolts back down. The metal will likely give after a while, being the tubing is thinner than I would have liked, but using what I already have. I may end up putting in thicker steel tube later down the road.
I also drilled 3 sets of 3rd arm holes so I can adjust the lift pitch.
DSC00050.JPG DSC00051.JPG DSC00052.JPG DSC00053.JPG DSC00055.JPG DSC00056.JPG
This is the depth gauge wheel assembly I built a while back.
I have some coming to plow day without a tractor due to the distance to pull a trailer, so I want to have extra tractors for them to plow with.
  • powerking56, MH81, KennyP and 2 others have said thanks
#2 Delmar OFFLINE
Delmar
  • 2,568 Thanks
  • 2,574 posts
Posted August 19, 2012 - 01:10 PM
Very nice set up there. the slide hitch is way cool. ought to work great!
  • olcowhand said thank you
#3 KennyP ONLINE
  • 34,230 Thanks
  • 43,347 posts
Posted August 19, 2012 - 01:11 PM
Looks good, Daniel! Ought to work fine for now.
#4 Cvans OFFLINE
  • 5,774 Thanks
  • 5,734 posts
Posted August 19, 2012 - 01:17 PM
Well thought out solution to the problem. I don't care what the rest of the guys here say, you still do nice, :smilewink:
And I envy you for having 3 plows. They are hard to find around here.
Is that plow new? Doesn't look to have ever been used.
#5 olcowhand ONLINE
  • 38,038 Thanks
  • 30,448 posts
Posted August 19, 2012 - 01:38 PM
That is FOUR plows Chris! The one in the pic has maybe an hour's use on it. Guy placed an ad as a 12", which Brinly did make a 12" sleeve model. I called ahead & told him how to measure it to be sure, and both he AND his buddy measured & said "yes, it's a 12". So I hop in my Jeep & drive 65 miles to pick it up for $100. Get there & it's a 10"!!!!!!!!!!! I already had two at the time, so was gonna turn home empty handed. He asked :"what would you give?" . I said I had no need for another one, but would give $75. He took it.
Then later I went to the auction where I got those HUGE tires for my Allis 620 & bought a Sears branded 10" plow for (I forget), maybe $50. The Sears has no wear at all either. If the plow day goes well, I may hang onto all 4 plows, but then who knows, selling a couple could finance another tractor adventure! :smilewink:
#6 Cvans OFFLINE
  • 5,774 Thanks
  • 5,734 posts
Posted August 19, 2012 - 02:09 PM
I had a Sears but it didn't have the crank angle adjustment on it so I sold it again. Some day I'll find one and then watch out.
#7 JDBrian OFFLINE
  • 9,596 Thanks
Posted August 19, 2012 - 02:24 PM
That's very nice of you Daniel to have tractors set up for the tractorless to use on your plow day. With people sharing, those 3 tractors will give a lot of folks a chance to enjoy the fun. :thumbs:
#8 MH81 OFFLINE
  • 29,909 Thanks
  • 29,738 posts
Posted August 19, 2012 - 04:23 PM
Daniel, as always, great work!
That's pretty much the new benchmark for hospitality... Building something just so people can borrow your stuff for a day...
#9 olcowhand ONLINE
  • 38,038 Thanks
  • 30,448 posts
Posted August 19, 2012 - 05:09 PM
Satin black paint is drying on it now. As for going to the trouble for a day.... IF George & Grand get to come down to my plow day, they said they'd likely not be able to tow a trailer with tractors due to the expense, and NO way they will be here & not have a tractor to plow with! So I'm putting all the outfits together that I can so they & at least one other besides them can also plow.....till I run out of fuel! :smilewink:
#10 HDWildBill OFFLINE
  • 8,971 Thanks
Posted August 19, 2012 - 07:40 PM
Looks good Daniel. You and Kenny are a good encouragement for me to try things I wouldn't ordinarily do.
