New Grippers
26 replies to this topic
#16 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted July 23, 2010 - 09:05 AM
Getting wheels blasted and primed today.
Hope to Paint Friday and mount Sunday.
Pics when mounted and on tractor to come.
#17 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted July 25, 2010 - 08:10 PM
FINALLY! :smile1:
Got these pups mounted.
Here are the Pics.
IMG_0591.jpg Posted Image
#18 daytime dave OFFLINE
  • 4,936 Thanks
  • 6,582 posts
Posted July 25, 2010 - 08:14 PM
They look great. Nice looking set up there.
#19 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted July 25, 2010 - 08:57 PM
The tires make for a mean looking tractor. They look very good on there.
#20 mjodrey OFFLINE
Posted July 26, 2010 - 04:42 AM
Those tires look really good on there.
#21 hydriv OFFLINE
hydriv
  • Validating
  • 71 Thanks
  • 583 posts
Posted July 26, 2010 - 07:35 AM
If you want them to work at their best, then you'll swap them side for side.
#22 mjodrey OFFLINE
Posted July 26, 2010 - 07:54 AM
hydriv,
I know if you turn those tires around they will wear better and cause less damage to soil ( grass ) ,but what other advantages are there by doing that ?
#23 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted July 26, 2010 - 08:15 AM
Hydrive
You made me go back and look at my pics. I was sure I mounted them in the correct direction. Farmer style. :smile1:
We did mounted ag threads backward for blacktop pulls and some farmers would mount backward to improve road wear.
Neither will be an issue here and I am hoping for a little more interaction will the ground during turning.
#24 olcowhand ONLINE
  • 42,468 Thanks
  • 31,825 posts
Posted July 26, 2010 - 08:16 AM
hydriv,
They will track better in soft/muddy ground. Since the wheels will essentially be "pushing" instead of pulling, the tread has to be reversed to get the "V" of the tread to hook up. That said, I have mine setup as rears simply because I like the look better.
#25 mjodrey OFFLINE
Posted July 26, 2010 - 09:54 AM
OH I see ,If they were powered wheels,then they are OK.But being none powered wheels,then backwards is better ?I didn't realize that .I know if you are running them on pavement then they should be backwards so as not to wear as quickly.
#26 hydriv OFFLINE
hydriv
  • Validating
  • 71 Thanks
  • 583 posts
Posted July 26, 2010 - 04:15 PM
And that's the whole point of swapping them side for side.
If your tractor was front-wheel drive or 4 wheel drive, then you would have them mounted correctly. But your tractor is 2 wheel drive at the rear and the front axle is passive. Here's my snow removal unit. The unit on the left is one of the very few All Wheel Drive Champion graders in Ontario. On that one, we use the same type of rubber all the way around. The units that have AG bar tread rubber always have the front tires mounted opposite to the rears so as to get maximum bite when turning. Out of the seven units I own, 5 are fitted with a wing blade for snow removal. All units are articulated to help them turn 90 degree corners in subdivisions when you have a moldboard blade and wing blade filled with snow.
It is very common for graders to run their fronts this way no matter if they are in Alaska, Michigan, Texas or Florida working in the sand. I have had this very conversation with other GT owners in the past. When they finally agree to try the tires the other way, they are quite surprised at the difference it makes, especially when it is slippery.
Edited by hydriv, July 26, 2010 - 04:23 PM.
#27 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted July 29, 2010 - 07:23 AM
I'll give that a try.
Thx. Hydrive.
