Nova Ii Electronic Conversion
9 replies to this topic
#1 Acableguy06 OFFLINE
Acableguy06
  • 8 Thanks
  • 21 posts
Posted August 18, 2012 - 09:59 PM
Has anyone used on of these on their 16 HP Briggs?
http://www.ebay.com/...984.m1438.l2649
Looks pretty easy, I was just wondering if there where any tips or tricks on it with these old motors? It does say this system will not work on flywheels with multiple magnets. I wasnt sure if the old Briggs has several mags or not.
Any thoughts?
#2 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted August 19, 2012 - 03:52 AM
There is one of those on my MF10 motor, but I have never had it running, I may get it running today.
  • Acableguy06 said thank you
#3 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted August 19, 2012 - 06:15 AM
Should work fine for you. The only problem I've heard of or experienced myself, was a backfire on startup. If you experience that, just reduce the spark plug gap, a few thousandths at a time, until it goes away. Your engine should then start and run fine.
#4 mjodrey OFFLINE
Posted August 19, 2012 - 06:17 AM
Not that brand,but I have used them,and they work good.
#5 Acableguy06 OFFLINE
Acableguy06
  • 8 Thanks
  • 21 posts
Posted August 19, 2012 - 10:52 PM
Ok, thanks for the feedback, looks like im going to give it a try. I found another seller that has it for just under $11.00 and free shipping...cant beat it!
#6 Acableguy06 OFFLINE
Acableguy06
  • 8 Thanks
  • 21 posts
Posted August 23, 2012 - 07:17 PM
Well, I received my Nova II electronic kit and put it in. Took about 30 Mins to do a proper install, after I just threw it on to see if it worked. All I can say is I am a believer in these now. This thing runs better than it ever did! I am a very happy person that this took care of my issues I was having. Best $11 I have spent in a while.
#7 caseguy OFFLINE
  • 1,628 Thanks
Posted August 23, 2012 - 07:55 PM
That's great that it works so well for you! :thumbs: Did it come with any literature that says what engines and models it will work on?
#8 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted August 24, 2012 - 04:25 AM
Great to hear that you're happy with the Nova II. I like it also.
#9 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted August 24, 2012 - 02:47 PM
My new white gt1650 has this module on it so it should work on your tractor. I haven't been able to run my tractor around yet since the spindles are broken, but it seemed to start and run fine....
Edited by rajkowski@ymail, August 24, 2012 - 02:52 PM.
#10 Acableguy06 OFFLINE
Acableguy06
  • 8 Thanks
  • 21 posts
Posted August 24, 2012 - 09:13 PM
It will work on any single cylinder engine as long as it is NOT electronic ignition, or have multiple magnets in the flywheel. Works with magneto coils only. It will work regardless of flywheel polarity, all you have to do is switch the hookup on the module and your good to go. No sending it off to have it re polarized.
  • caseguy said thank you
